Gear selector lights not working consistently!
07-12-2013, 07:19 AM | #1 |
Rep 15
My car(2007 E90 sedan) is a Pre-Lci model with Auto tranny. A few months back, the problem started with the R light not coming on when selecting reverse (the orange light in the interior trim beside the knob: http://www.e90post.com/forums/attach...1&d=1268716638).
Yesterday, I discovered the same thing occurring when selecting the D mode. It doesn't light up unless you move the knob back and forth quite a few times or just tap it in your direction (when D is selected). Even when it lights up, the selection of DS mode and back to D mode will cause the D indication light to stop working again unless I repeat the fiddling thing again. What could possibly be faulty here? Update: No fault codes whatsoever. Last edited by Joshua33; 07-12-2013 at 08:24 AM.. |
07-12-2013, 07:30 AM | #3 |
Rep 15
My model is a 2007 Pre-Lci 320i E90. I know nothing about fault codes whatsoever, the light comes on when I fiddle with the gear knob as I've stated, but would just go out again as soon as I move the knob or even touch it, lol.
I would appreciate every bit of help you can offer as this thing is driving me nuts. |
07-12-2013, 07:51 AM | #4 |
Rep 15
I just rechecked. There are NO fault codes registered. And the dashboard indicator works just fine, it's just an issue with the lights switch underneath the gear selector or something...
07-12-2013, 08:40 AM | #5 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Open it up and make sure the wiring is not frayed.
http://www.e90post.com/forums/showthread.php?t=511799 |
07-12-2013, 09:06 AM | #6 | |
Rep 15
07-12-2013, 04:42 PM | #8 |
8
Rep 297
Electrician my friend...save yourself the worries...
08 335i MSPORT & PR PKG/aFe St2 DCI/AA BOV kit +DP/SprintBooster Stage 2/Avant Garde 19 rims/ HNK V12 Pro Tires/BMS Wheel Spacers/ E92 M F n B kit incl blk kidney grills and sensors/Afe mach Exhaust. M3 skirts, DNA map 3
07-12-2013, 07:05 PM | #9 |
138
Rep 2,731
Pop the cover off around the shifter. There is a connector underneath that hooks up to that lighted shift display. Perhaps it is loose. Disconnect and reconnect.
The shift boot pulls right off, just reach inside the leather part and pull up against the edge of the black plastic trim. The whole black plastic trim will pop off the interior center trim panel. |
07-12-2013, 09:26 PM | #10 | |
Rep 15
07-12-2013, 09:29 PM | #11 |
Rep 15
07-13-2013, 07:10 AM | #12 | |
8
Rep 297
BB
07-13-2013, 06:17 PM | #13 | |
Guest
Rep n/a
Drives:
07-13-2013, 09:24 PM | #14 | |
38
Rep 823
/// OEM /// |
