Switching Steptronic modes
12-03-2005, 02:48 PM | #1 |
Rep 59
Can you switch Steptronic modes -- from D to DS or from M to D, for example -- at any time, regardless of engine speed?
325xi Steptronic / Arctic Metallic / Black Leather / Aluminum Trim |
12-03-2005, 03:02 PM | #2 |
101
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
yes anytime you dont cause the engine to exceed red line revs by dropping down the gear changing from d to ds. the car will not let that happen until it is safe to. changing fom m to d you can do anytime as d will chae to a higher gear, dropping the revs.
i change between all modes from time to time, the most enjoyable bei on uohill mountain roads in m mode. ds is great for windy country roads and for getting a quick head start oif you are first in line at the red lights as it turns green. enjoy.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
12-03-2005, 04:35 PM | #3 |
97
Rep 2,041
Drives: e93-35 May08 ED
I went from D to DS to M pretty much anytime that I felt like doing it myself. This was in the Alps.
5-2-08 e93-35 ED Montego w/Jade Grey, Step w/Paddles, PP, SP, CA, hot seats and iPod.Awaing re-delivery soon.
Debadged 330xi ED 11/14/05 Auto/Mystic Blue/Gray leather with Alum/PP/SP/CA/Fold-down rear seats/Alarm. Sold to Carmax on 6/7/08 with 50,624 miles on clock |
12-03-2005, 05:02 PM | #4 |
264
Rep 2,576
how do you get to DS? i cant figure it out for the life of me.
12-03-2005, 05:22 PM | #5 | |
97
Rep 2,041
12-03-2005, 05:28 PM | #6 |
264
Rep 2,576
o, i thouhgt that was manual. Nice. sport just holds the gears longer correct, well that and eats up alot more fuel?
12-03-2005, 05:41 PM | #7 | |
97
Rep 2,041
Not sure, but I believe it does drink more gas in DS mode.
12-03-2005, 06:11 PM | #9 | |
//Mdicted
347
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
http://www.e90post.com/forums/showth...ght=steptronic http://www.e90post.com/forums/showth...ght=steptronic http://www.e90post.com/forums/showth...ght=steptronic http://www.e90post.com/forums/showth...ght=steptronic hope it helps you have more fun! gRRRRRRRRR
12-04-2005, 08:37 PM | #10 | ||
Rep 59
Thanks for the replies to my newbie question -- I'm only halfway through the break-in on my E90, which is my first Bimmer.
And my apologies -- I had skimmed through most of the earlier Steptronic-related threads before I asked the question, but I see now that my it had already been answered in the exchange below. Anways, thanks again! I absolutely LOVE my E90 and this forum has only added to my enjoyment and understanding of the car! Quote:
12-04-2005, 11:56 PM | #11 |
155
Rep 6,158
make sure you're in neutral and stopped before switching into DS mode,
also to shift back you'll have to stop, put in neutral, shift to reverse, drive 10 feet backwards, then shift back to D you don't want to damage your transfer case |
12-05-2005, 12:13 AM | #12 | |
101
Rep 3,566
You forgot to mention that you can also be travelling up to but not faster than 30kmh in a forward direction before putting the transmission in reverse.
12-05-2005, 12:12 PM | #14 | ||
Rep 59
12-05-2005, 12:53 PM | #16 | |
101
Rep 3,566
ward, then i decided to do a little non offensive clowning around enjoy the car.
12-05-2005, 06:22 PM | #17 |
Rep 235
Drives: 320d SE;Mazda MX-5
One thing I feel is a shame is that if you switch to DS you are able to manually change up and down the gears, but it doesn't tell you what gear you are in until you actually change either up or down, at which point it will tell you.
So if I knew I wanted to be in 3rd gear for a particular bend, I'd move the lever to DS then quickly up and down again to get it to display the 'M...' gear, but do that quickly enough that it didn't actually change the gear. (and move up then down, not down then up, just in case I didn't move the lever fast enough). Otherwise I'd be in DS but not know which gear I was in (and it wouldn't hold that gear for me either). Jon. |
