High mileage (100k+) N54/335i preventative maintenance items?
06-23-2013, 01:27 PM | #1 |
Dominator of Deep South curvy roads
51
Rep 340
I now have 101,800 miles on my 335i. It's a 02/2007 build, and I have owned it since its birth (even flew to Munich to pick it up from the old Euro Delivery facility in Freimann, Munich, Germany). Hard to believe this much time and driving has passed by!
I have no desire to ever sell this car, and hope to be it's only owner. Love it as much as Day 1. I want to see what maintenance items I should consider to keep it running as long as possible....even though it has been driven HARD throughout its life. Unfortunately for the first few years (before I knew better), I would every once in a while drive it hard when the engine was still cold. However, I made sure to go at least by the book with maintenance. I even changed all fluids at around 80k even though they are considered "lifetime" by BMW standards (manual tranny, power steering, and radiator flushes), and changed the oil at least every 7.5k miles. Here are my major repairs so far: -Turbos replaced under warrranty around 45k (wastegate rattle issue) -HPFP replaced under warranty around 70k (never went bad, just asked the dealer to do it) -Fuel injectors replaced under warranty around 70k (again, never went bad, just recommended) -A/C blower motor switch replaced around 70k (failed) -Strict adherence to maintenance schedules (as described above) I still have never done these items, but am considering -Intake valve walnut blasting -Replacing valve cover, oil filter, and oil pan gaskets -Replacing dual mass flywheel and clutch (this was my first manual trans car....dual mass flywheel springs have been shot for probably 70k miles now, but clutch is still good) Is there anything else that you guys would add to the list here? Thanks! Attaching a pic of the car rolling to 100k!
-'07 335i coupe (build date 02/2007) - Space Grey/Black Dakota/Dark Burl - 6MT/ZPP/ZSP/Nav/CA/Heated Seats. Acquired in Munich 3/2007 via European Delivery. 16 years and almost 220k miles of pure joy!
-'06 911 Carrera S - Black/Black - Full Leather/Sport Chrono/Porsche Sport Exhaust/Nav - 80k miles. Acquired 1/2021. One needy old German car just wasn't enough! |
06-23-2013, 04:09 PM | #3 |
145
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
Congrats on 100k! Yes a walnut blasting is a must! The car will run a lot smoother. If you haven't replace spark plugs and ignition coils I would do those as well. But it's likely they were done as maintenance.
EDIT: How about getting a new PCV hose and upgraded RB PCV valve? Its likely the original system is dirty and worn. |
08-05-2013, 06:20 PM | #8 |
10
Rep 372
Is it just the angle or are you running a little warmer than normal? Mine is almost always right in the middle and I had an 07 with oil cooler. I'd do cooling bits for sure, if you haven't already as mentioned above. But hey, I could be completely off base. I'm known to be wrong.. often.
08-05-2013, 06:25 PM | #10 |
19
Rep 345
Drives: '08 335i, '03 Kawa Z1000
+1 for walnut blasting! I had it done at 62k under warranty and the difference is night and day!
08-05-2013, 06:26 PM | #11 | |
BMW Fan
449
Rep 725
08-05-2013, 07:43 PM | #12 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
08-05-2013, 08:16 PM | #15 |
7
Rep 154
Do the water pump and t-stat as soon as you can. Mine failed at 103 k miles and left me on the side of the highway.
Do it before it goes bad. |
08-05-2013, 08:42 PM | #16 |
10
Rep 372
08-05-2013, 09:10 PM | #17 |
Rep 12
congrats! i don't ever plan on getting rid of my car, i don't know that i'll ever have the chance to buy another convertible so i'm holding on to this one as long as possible
eric b |
08-05-2013, 09:36 PM | #18 |
51
Rep 340
Guys, sorry I never responded to anything in this thread!
Jdub - Regarding the flywheel springs....the drivetrain feels like it has play in it. It is most noticeable when decelerating after accelerating...ESPECIALLY in 1st gear. smallseafishie - Thanks for answering that question. There were several changes that BMW made in Mar-07 (1 month after my car was built)...raising the max temp on the gauge was one (along with a couple extra chome interior pieces, memory buttons on the Nav, and the 6FL (I think that's right) iPod integration option. So far, I'll add the water pump, thermostat, PCV valve, and serpentine belt to my list. Thanks guys! The car now has 103,500 miles, and will see a track day at Road Atlanta on Sept. 7th!
08-05-2013, 11:34 PM | #19 |
128
Rep 836
Differential Fluid? Hard to believe youre at 100k and never had a HPFP changed. You lucked out there.
Previous Ride 2007 335I Coupe / Space / Black Dakota / Gray Poplar / ZSP / ZPP / Step / Paddles / Nav / Hot Seats / IPOD/ Xpel HL
Current Ride 2016 M4 / Mineral Gray / DCT/ Full Black Leather / 19in Gunmetal / Executive /LED/Ohlinds RT/SSR DP-CP-Intake/AP Essex 9668/Bootmod STG 2/DINAN HE |
08-08-2013, 11:11 AM | #21 |
The power of V!
99
Rep 1,971
Drives: 2007 335i coupe steptronic
Garage List 1998 Lexus Gs400 [0.00]
2010 ebony & ivory [0.00] 2006 BMW X3 [0.00] 2009 pics [0.00] 2009 e92 335 xdrive [0.00] |
gives me hope. Very nice.
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm. |
08-08-2013, 11:19 AM | #22 |
1435
Rep 4,724
I'm at 99, and I just had my tranny Fluid changed, and I'm getting my differentials and transfer case fluids changed. (XDrive problems)
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
