Cold start engine revving
06-22-2013, 04:44 PM | #1 |
112
Rep 159
I'm a new owner of a 2011 335 and am experiencing idle surging upon cold start. I took it to the dealer and they basically said its throwing no codes so its not a problem and it's "normal" for this to happen especially because it's only temporary (first 20 seconds or so after start). I noticed at first that it seemed to only occur when the AC compressor kicked on right away however its doing it now with the AC off and just about with every cold start. I found a few threads on similar issues but wanted bring some attention to see if anyone has experienced this exact issue with an N55. Check out the video:
06-22-2013, 05:27 PM | #2 |
419
Rep 1,068
I'd say def not normal. N54 here but mine does an initial idle spike like the vid at the 10 sec mark, however it DOES NOT continue like that one.
Carbon build up? Hard to imagine on a 2011 though. Maybe slight injector issue? |
06-22-2013, 09:06 PM | #3 |
40
Rep 290
My 2011 335xi also does the same thing. If I stab the throttle, it seems to settle down. Also, I don't think mine does it unless the ac is on. If I manually turn off the ac before I turn the car off, it doesn't seem to idle erratically when I go to restart it later.
Is not normal but I've yet to encounter a serious problem as a result. Wonder if its just a software issue?
2011 BMW 335i XDrive Msport (auto)
06-22-2013, 10:35 PM | #4 |
112
Rep 159
Carbon build up now that you mention it could be a culprit. I've had the car about a month and all of my driving is short distances (<10 miles typically). Poor thing barely gets its oil warm most trips. That would also explain the increase in frequency I've seen over the last week.
06-22-2013, 11:43 PM | #5 |
681
Rep 3,696
Definitely not normal for any vehicle. I just came from the BMW HQ event they had about a week ago. This not anywhere near the, "We have an obsession for perfection in minor details for our luxury owners..". Surging/bouncing idle on startup is NOT obsession for a great BMW experience when I start "my" car in the early morning. It's definitely NOT the way "I" would want to start my morning when I get into the "Ultimate Driving Machine".
Just spit some of that back at your SA, then walk out and start going to a new BMW service location. Your car on a cold start up should idle high for a moment (about 1500 rpm-ish) and then gradually taper down to a rock solid 750 RPM. I would estimate about 2 or 3 seconds per 100 RPM drop (ball parking here)... but you get the idea that it is a linear diminishing RPM from the initial start up spike. Never should it bump upwards... only downwards towards the target RPM of 750. The reason you get the spike on cold start is because the ECU doesn't want the car to stall out... once its running it gradually moves towards it's target RPM in a closed loop. If your bouncing the RPM's... that is only going to happen if you have a faulty Throttle Position Sensor, you are tapping on the gas peddle, or vacuum leaks it's compensating for. Next question is.... after a few minutes the car should switch to open loop... wondering if you are having any idle issues then? |
06-23-2013, 03:14 AM | #6 |
Audi Convert
9
Rep 362
I think there are also emission requirements for the "normal" RPM spike at startup. The catalyst needs to warm up quickly in order to keep the Nox emissions within federal guidelines. At least this is what I have been told.
I suspect that if you could get a reading on cylinder misfires, you would find that the first couple of minutes you have a ton of misfires. These are dealt with by the ECU adjusting timing, fuel and other engine parameters. If I am right, though this is annoying, it will not damage the car. I agree 100% that the Ultimate Driving Machine should be smooth from the moment you crank the engine. If a Honda civic can run smooth for 200K, then it is not too much to ask for a BMW to run smoothly for 50K to 100K miles. |
06-23-2013, 11:27 AM | #7 |
1559
Rep 4,109
Drives: BMW M3
Absolutely not normal. Something is wrong, no idea what. I have a 2011 N55 and it does what others have said - goes to maybe 1100 at first, then settles to just below 1000 for 10 secs then 750rpm idle, stable.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
06-23-2013, 11:42 AM | #8 |
19
Rep 345
Drives: '08 335i, '03 Kawa Z1000
I have an N54, but this looks very similar to issues I was having recently. My idle surge was not nearly as pronounced as yours, but I also had symptoms while in motion that almost felt like a transmission knock.
To make a long story short the first dealer said it was "normal". After giving them a piece of my mind, I brought to another dealer and they replaced spark plugs and coils. Issues got better, but didn't go away completely so I brought it back to them and they replaced the injectors and did carbon blast. That did the trick. Keep on them until they fix this. If they give you a hard time tell them to get the regional field engineer involved. That's what mine did to get approval for the carbon blast under CPO warranty. |
06-23-2013, 08:01 PM | #9 | |
112
Rep 159
06-24-2013, 07:10 AM | #11 | |
535
Rep 1,873
Earlier BMWs (like my E39) and other German vehicles have used a secondary air pump to meet the same requirement. If you don't have the pump, then the engine is usually programmed to have a faster idle and run with retarded timing to send burning fuel straight into the cats to light them off. My E39 would start and settle right to 600rpm from dead cold, but with the secondary pump running for anywhere from 10-90 seconds depending on ambient/engine temperature. |
06-24-2013, 06:36 PM | #13 |
86
Rep 1,849
Mine will surge over and over for maybe 20 seconds then drop to 750. This happens maybe once every other week or so. Sometimes I will also get a lurching start from a red light, most of the time not. I can't figure out what the hell is going on, but it's uncommon enough that I have been putting off making an appointment at the dealership.
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
06-24-2013, 09:17 PM | #14 | |
Gateropode
329
Rep 2,848
06-25-2013, 07:11 AM | #15 | |
535
Rep 1,873
And, almost 10 years later, here we are. Everyone and their brother has some kind of rough idle, bouncy idle, sputtering, "not like it used to be" etc... Honestly I'm not surprised at all. But, I find myself owning one of these engines. Valvetronic leads to a bunch of technical and performance advantages but smooth idle sure isn't one of them. |
