BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > thrust arms
      06-21-2013, 05:05 PM   #1
thejackyltm
21
Drives: 2013 335MSport
thrust arms
question..dealership said my thrust arms need replacing. they wanted 350 to do it. is this something i can do myself? and also, read that you can use the m3 ones instead which id much rather do. is this al true anyone know?
      06-21-2013, 05:38 PM   #2
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
You can do it yourself and use the M3 ones. What problem are you having and how do they know it's the control arms for sure?
You will also need an alignment after the work is done.
      06-21-2013, 07:19 PM   #3
Denny347
Denny347's Avatar
347
Drives: 2008 M3 E90
Was there a symptom to those going bad?
      06-21-2013, 11:24 PM   #4
thejackyltm
21
the dealer said they didn't need to be done right away wasnt bad. But, he said ill probably notice some steering wheel shaking etc. and i have been but I blamed it on my new wheels and tires being the culprit. he said the rubber part is going bad on the drivers side, and i have the extra cash now so i figure might as well try and get it done if need be. is it difficult to change?
      06-22-2013, 05:45 AM   #5
Denny347
Denny347's Avatar
347
Drives: 2008 M3 E90
I haven't changed mine but I've looked into it. It looks like an hour or so per side for the average DIY'er. Puller is about the most specialized tool you will need and those can be borrowed at a local parts store.
      06-22-2013, 07:10 AM   #6
cleex024
104
Drives: 2008 BMW 335i Coupe
Just buy the entire thrust arm and just swap it out. .. you just have to uninstall the tire and gender liner then un bolt and replace. ..very simple
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
      06-22-2013, 08:05 AM   #7
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
Originally Posted by cleex024 View Post
.. you just have to uninstall ..... gender liner then ...
Video please!
      06-22-2013, 09:15 AM   #8
CALWATERBOY
CALWATERBOY's Avatar
146
Drives: 2009 E93 N54
Which arms?
      06-22-2013, 09:16 AM   #9
Denny347
Denny347's Avatar
347
Drives: 2008 M3 E90
      06-22-2013, 09:17 AM   #10
CALWATERBOY
146
M3 arms preferred for lightness, stiffness; Delrin instead o'rubber. A few photos HERE
      06-22-2013, 09:23 AM   #11
CALWATERBOY
146
Originally Posted by Denny347 View Post
#6
Tension Struts. A nut on one end; bolt on the other - no problem.
If using M3 parts, dimension may be somewhat diff, a good thing. Do the wishbones too, and always do in left/right pairs. HPAutowerks a good source.
Always align after suspension work!
      06-22-2013, 09:26 AM   #12
CALWATERBOY
146
And while you're in there, M3 sway [anti roll bar] wouldn't hurt.
      06-22-2013, 11:24 AM   #13
cleex024
104
Originally Posted by ajsalida View Post
Video please!
LOl whoops meant Fender liner
      06-22-2013, 01:06 PM   #14
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Easy job! Here is a DIY I wrote.
http://www.e90post.com/forums/showthread.php?t=788761
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      07-30-2013, 09:52 AM   #15
badassfajita
40
Drives: 2013 e70 3.5i
Is there a good reason to replace the entire arm as opposed to just the bushing?
Thanks for your help in advance.
      07-30-2013, 01:49 PM   #16
trohde78
trohde78's Avatar
74
Drives: 2007 e92 335i 6MT
Yes, as you also get a new ball joint that's at the other end of the arm for not much more money. I just replaced my arms with the Meyle HD brand when one of my bushings leaked out.
