06-19-2013, 12:39 PM | #2 |
511
Rep 1,435
Ive run different pressures from 33 up to 40. I have found that running 36 all around is the most comfortable and wears evenly. Too much air and the tire will wear in the middle. Not enough air and the tire will wear on the outer edges. 36 seems to be just right. I check it weekly and adjust accordingly. Always check pressures when tires are cold. The coded option that displays tire pressure is very useful. Its very interesting to see the pressures and temps adjust as you drive.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
