trunk compartment secret accessory area
06-17-2013, 01:12 PM | #1 |
Rep 22
I lifted the cover in the trunk where normal cars keep the spare tire....and there's a place for some canister-shaped thing to rest, with unused brass screw holes to secure it (I guess.) What is this for?
06-17-2013, 01:17 PM | #2 |
Leeeroy Jankins
31
Rep 423
That's where the drugs go....
e90 LCI w/ -= VRSF 7" FMIC =-
-= Cobb: Stg1 +FMIC Aggressive ST =- Last Install: BMS DCI + Caliper/Drum Paint "If you're not 1st, you're last" -Ricky Bobby |
06-17-2013, 01:37 PM | #5 |
81
Rep 6,092
what are the drugs for? you can try one and find out
06-17-2013, 01:44 PM | #6 |
Leeeroy Jankins
31
Rep 423
I keep my jumper cables in there. I think certain non RFT spares can fit there. Found the below response from a 2yr old similar post.
"The molded spaces under the trunk mat are designed for the OEM BMW jack and tire tools, which of course don't come with the car. However, if you buy a donut spare kit that comes with the OEM tools, they are a perfect fit under there, even the jack. There is still some space left over for gloves, reflectors/flares, compressor, etc."
06-17-2013, 01:52 PM | #8 |
170
Rep 1,843
So how do you fit the jack there? Or is the E60 kit being sold now different somehow than the "real" E92 kit? I know the parts will physically fit, but there's not any way to secure them from sliding and bashing around. I got all my stuff from Tischer.
06-17-2013, 03:09 PM | #10 |
Rep 22
It's too bad that new jack kit doesn't fit well. I was actually hoping this area was for securing the mobility kit parts that I just ordered. When I saw those empty brass screw holes it just made me think my car might be missing something important!
06-17-2013, 03:25 PM | #12 |
I'll get back to you
7562
Rep 2,132
my oem space-saver does not fit in there.
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
06-17-2013, 03:47 PM | #13 |
Bavarian Murder Weapon
Rep 249
Drives: E90 335i 6MT
06-18-2013, 02:16 PM | #14 |
170
Rep 1,843
Actually at one point in time I did find a part number for a foam insert for the little well in there to hold the mobility kit for the M3, I ASSume that M3 and 335i use the same trunk floor insert.
I don't have any details on the jack kit though. |
06-19-2013, 10:41 PM | #16 |
18
Rep 270
I picked up a used older BMW jack off fleebay that fits perfectly in my e93 which may be smaller than e90/e92. May have been from the e46, i don't recall.
06-19-2013, 11:47 PM | #17 |
681
Rep 3,696
Old SNL skit, "... You put your weeeeeeeeeeeeeed in there....."
06-20-2013, 06:18 AM | #18 |
Rep 22
Good tip on the used jack Snow King, I just ordered a used one and I'll see how it fits. (I had no luck finding an OEM weed storage adapter kit on ebay, but a lot of other interesting stuff showed up when I searched for one.)
06-20-2013, 08:40 AM | #19 |
170
Rep 1,843
06-23-2013, 09:25 AM | #20 |
Rep 22
The jack I bought rests securely in the compartment. Lay the jack on the the two U-shaped cradles with the white text facing you, with the jack slid over to the left so that the white jack pad is in the recessed area to the left of the leftmost cradle.
06-23-2013, 11:34 AM | #21 |
EL JIMMY NEURON
44
Rep 1,180
That's where the cut up human remains go.
2007 Jet Black E90 328i
Thread: http://www.e90post.com/forums/showthread.php?t=825249 Instagram: manutd_as |
