Checking coolant strength
06-15-2013, 06:37 PM | #1 |
59
Rep 913
Hey all,
My coolant is low. Float is about 1.25" below top threads. But no coolant light is coming on. BMW parts department is closed till Monday, so I can't get any coolant. Was thinking of just adding distilled water. But I don't want to add so much that freezing point is significantly altered. Does anyone know if you can just use a plain old antifreeze tester? Or will it not read properly with the bmw coolant? Was thinking as long as freezing point is high enough, could add water and check strength again. Rinse, repeat. Last edited by foghat; 06-15-2013 at 07:07 PM.. |
06-15-2013, 09:11 PM | #2 |
178
Rep 582
you cannot add too much water for what you're describing we are talking a cup or two of water in a multi-multi-gallon system. you would have to add a gallon plus to alter it negatively and even then....
06-15-2013, 09:15 PM | #3 | |
681
Rep 3,696
But I would not contaminate it with off the shelf coolant or any water/distilled water. Let your SA advise you on how to check it and top it up for free for you (Top up your washer fluid while you are at it too). |
06-16-2013, 01:37 AM | #5 | |
681
Rep 3,696
Worst comes to worst, just go in for an oil change (with a coupon from the dealership website or a competing BMW dealership coupon for them to cross honor) and they will do the oil change for $$ and top up all fluids for free. |
06-16-2013, 02:49 AM | #6 | ||
19
Rep 278
06-16-2013, 02:53 AM | #7 | |
138
Rep 2,731
Maybe if you bought it there, even then once it is out of warranty a lot of dealers aren't going to be too helpful. No matter how old though? doubt you could drive an e21 or e30 up to the service bay and say top all the fluids up please. |
06-16-2013, 03:07 AM | #8 | |
681
Rep 3,696
Agreed, distilled water is fine... but what about the mixture ratio? If he tops up with distilled water and no coolant, how is he to know what his mixture rate is now? If your adding 50/50 pre-mix of BMW coolant... then you know you aren't messing up the ratio compared to what it is already. |
06-16-2013, 03:09 AM | #9 | |
681
Rep 3,696
From what I was told the last time I had it topped up, "... just bring in the car and we will top it up for you, better to have us do it rather then mess it up and it's always free to have done". |
06-16-2013, 04:05 AM | #10 | |
19
Rep 278
One of the dealerships I've been to even came up with a "top up charge". If your car is in for service they pretty much charge you a flat fee (like $7) and say they top up all the fluids (coolant/oil/windshield washer/PS fluid). Correct me if I'm wrong, but the coolant sold at dealers is full strength (not pre-mixed) and you have to mix it yourself. Well, at least I haven't seen pre-mixed coolant at Canadian dealerships. And if the car needs a slight top up (i.e. 100ml), the ratio change is very small (if it was a perfect 50:50 it'll change to 50.6:49.4, at 8l capacity).
06-16-2013, 07:03 AM | #11 | |
681
Rep 3,696
06-16-2013, 07:46 AM | #12 |
866
Rep 5,450
If it is that low and isn't leaking it probably means it has evaporated which means it is actually more concentrated than 50/50 as the water is all that evaporates and adding distilled water would be fine to top it up (especially since it is summer), then you would want to use a normal coolant measuring device to check the freezing boiling point if you were going to leave it like that. My guess is, that if that much has evaporated, then you are still on original coolant and you indicate you are driving a 2008 135i, so 5 years is time to change it anyway!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
06-16-2013, 09:11 AM | #13 | |
17315
Rep 18,737
06-16-2013, 11:12 AM | #14 |
295
Rep 2,202
Distilled is a go to top up. even tho you said it is an 1' below it wouldnt take tht much fluid to bring it to normal levels. More importantly tho you should check for leaks around the system.
06-17-2013, 06:58 AM | #16 | |||
535
Rep 1,873
BMW OE coolant is G-48, which has different properties than average off-the-shelf green stuff, but it's not the BMW logo that makes it special. Any old coolant tester will help test the strength and standard test strips will help you check the pH. This stuff is cheap enough that anyone with any DIY inclinations should have them. Quote:
OP: feel free to top up with distilled water for now. Check the strength as indicated above, change coolant every 2 years (3 max), and if you find yourself low again then you'll have to go find the leak. It's not normal to lose any coolant on an E90 and repeated top ups with distilled water will start to affect the concentration. What you should NOT do is try to make a 50/50 mix of anything other than BMW OE coolant and mix it in with what you have in there already. Compatibility is not guaranteed and then you could start to get yourself in some trouble. |
