e92 M3 parts that Fit e92 335i
06-09-2013, 11:51 PM | #1 |
87
Rep 559
i wanted to know what parts are DIRECT FIT from the m3 ( NO MODIFICATIONS ) to our 335i e92s
aesthetic appeal and performance wise. |
06-10-2013, 12:12 AM | #3 | |
136
Rep 1,598
But all those things you mentioned Andy aren't from an M3. To the OP these are some that I know. M3 Control Arms M3 Tension Struts M3 Strut Bars M3 Sway Bars M3 Steering Wheel M3 Competition Rims M359 Not much you can fit on our non M cars from an M3 without modification or some fiddling around with. Performance? engines are completely different so nothing? What are you trying to achieve OP? |
06-12-2013, 12:58 AM | #5 | |
87
Rep 559
Thanks, this is what i really wanted to know , what i really wanted to do is beef up the suspension really, i figured as much with the engine and body but thought there may have been a bit more interchangeable parts than whats been listed so far, with that said, are the aftermarket versions of the OEM M3 Control Arms , M3 Tension Struts , M3 Strut Bars , M3 Sway Bars better than the M3 versiosn...better as in quality, build, dependability etc.. |
06-12-2013, 07:22 AM | #6 |
136
Rep 1,598
No problem but pretty much the aftermarket M3 suspension parts are the same as OEM quality and handling since the original makers of the M3 suspension parts is basically rebranded into BMW.
06-12-2013, 07:33 AM | #7 |
JB4, BMS intake
17
Rep 244
Drives: White BMW 335xi Coupe
will m3 bumpers off of a m3 fit on our e92
06-12-2013, 07:37 AM | #8 |
65
Rep 554
Drives: E92 335i 6MT
No, M3 fenders are wider. There are plenty of replicas that are made for non-M3's.
06-12-2013, 08:43 AM | #9 |
JB4, BMS intake
17
Rep 244
06-16-2013, 12:45 AM | #10 |
87
Rep 559
just thought it would prob be a good idea when parts start going .. to swap em out with the M parts...... case in point ..the control arms, etc ..
so M3 Control Arms M3 Tension Struts M3 Strut Bars M3 Sway Bars is pretty much it.. |
06-16-2013, 01:10 AM | #11 | |
681
Rep 3,696
Just to make your life easier, here is the full kit for the M3 retrofit from Tisher BMW (GetBMWParts.com): http://www.getbmwparts.com/partlocat...catalogid=4462 You probably want to get the rear subframe bushings too while you are at it. - Faz |
06-20-2013, 07:27 PM | #13 |
81
Rep 6,092
the badge
