F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Megan Racing Camber Kit
Studio RSR
      06-08-2013, 12:25 PM   #1
slmdgee
Usofstance
Drives: 328I 6SPD
They finally came out with it, and its 250 dollars... What if we did a group buy?
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      06-08-2013, 01:02 PM   #2
scott@bmwhn
134
Drives: Msport X3
more info? I would have interest if its compatible with EDC equipped cars
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      06-08-2013, 02:50 PM   #3
slmdgee
Usofstance
Drives: 328I 6SPD
Megan Racing Rear Camber Kit BMW 3 Series F30 2012+
Part Number: MRS-BM-0311
*NOTE* As of April 2013 Megan Racing changed the color of ALL their suspension arms from Blue to Pink, we can not guarantee which color you will receive once you place your order, but we'll do the best we can to update our listings regarding which ones are available at this time in Pink since the Blue colorway will be discontinued once they sell out. For more information about this visit http://www.meganracing.com/products/...?special_id=16
2012-Current BMW 3 Series F30
Wheel alignment is absolutely crucial when modifying your car. Alignment can effect every aspect of your driving experience, from straight line stability, under-steer, over-steer, acceleration, braking and tire wear. Although stock components allow slight alignments from the stock suspension settings, they often are not able to properly align the car after the suspension has been modified. From the factory, most cars are set to have under-steer and for optimum tire wear at stock height; under-steer is often undesired from a performance standpoint but is always dependent on driver style, therefore the adjust-ability of the alignment of a vehicle is critical when tuning for speed. The clock does not lie and having the vehicle alignment can make seconds of a difference.
Megan Racing Inc. has developed reinforced and adjustable control arms to accommodate the needs of the aggressive and performance oriented tuner. Being constructed of a Lightweight Steel-Alloy which is able to withstand the stresses of extreme competition, these arms are powder-coated with a 3-Stage process to ensure durability and protection against the elements.
Megan Racing has now developed camber arms for the B.M.W crowd that will help attain a higher level of control and performance. Constructed of a Reinforced Rubber Bushing , these control arms remain light weight while being able to take the punishment of competition and extreme conditions. A 3-Stage powder coating process the control arms will easily combat the elements for years of performance.
SPECIFICATIONS & FEATURES:
- Made with high-strength and anti-cranking rubber material
- Rubber viscosity is around 2000KGS
- Direct replacement/ no modifications needed
      06-08-2013, 05:05 PM   #4
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
This is a rear camber kit which is nice and all but it's putting the cart before the horse. These cars need front camber if it's more balanced handling you want.
      06-08-2013, 09:45 PM   #5
slmdgee
Usofstance
Drives: 328I 6SPD
Yes! We need front camber.
      06-09-2013, 12:06 AM   #6
AMJAM
AMJAM's Avatar
Australia
33
Drives: 2013 Alpine 328I MSport
CKS Coilovers I believe have front camber plates for that
2013 Alpine White 328I M Sport ARRIVED
      06-09-2013, 12:08 PM   #7
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
True and they are a god option but the F30 needs a separate camber plate option so we can choose our coilovers/suspension.
I really just wanted to make sure people knew this was a rear kit before they spent the time sifting through the the not-so-great Megan Website.
      06-09-2013, 06:48 PM   #8
AMJAM
AMJAM's Avatar
Australia
33
Yeah their website is a shocker
      06-10-2013, 05:15 AM   #9
chugster
B0$$
chugster's Avatar
Drives: 2020 HS M2C
our cars does not have adjustable front and rear cambers? or is this kit for people who go for a stance layout and need more adjustments?
Prev:
2013 AW/Coral Red 328i Sportline- Mperf. Black Grills, Mperf. exhaust, Prem. pkg, Tech pkg, Lighting pkg, Heated seats, Sports 8spd w/paddles
2016 CWP STi FBO E85
      06-10-2013, 06:59 AM   #10
slmdgee
Usofstance
Drives: 328I 6SPD
We can adjust the rear but only so much, with this camber kit we can do more.
      06-18-2013, 05:28 PM   #11
M2-Motoring
Drives: 2012 BMW 328i
i can help with the group buy if anyone is interested.
      06-29-2013, 02:21 AM   #12
bavarianf30
bavarianf30's Avatar
Drives: 335i 14 s1000rr 17
Lets
Do a group buy this will be great guys!!!
      06-29-2013, 02:27 AM   #13
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
A Real Man would choose the color Pink!
Just sayin~
      06-30-2013, 08:58 PM   #14
AMJAM
AMJAM's Avatar
Australia
33
K-Mac suspension has 3 versions of camber plate for the F30. With the AUD slumping against the USD they are a pretty reasonable option. You can order from their website
      06-30-2013, 08:59 PM   #15
AMJAM
AMJAM's Avatar
Australia
33
These are for the front by the way
      07-04-2013, 12:35 AM   #16
F555
F555's Avatar
Indonesia
37
Drives: F30 - 335i
are these camber plate compatible for any coilover? like KW or Billstein?
or they're making it specific for their own brand?
      07-29-2013, 08:27 PM   #17
MrMikeHenry
Drives: 2011 E93 m3
im in for a group buy
      07-30-2013, 12:04 AM   #18
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
Hot pink? I'm in
      06-20-2014, 10:58 AM   #19
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
will this make the ride more stiff ?
what about it's made of steel and stock made from aluminum isn't that a lower quality ?!
what will I expect from installing them ?
      06-20-2014, 11:09 AM   #20
rustyminded
248
Drives: BMW 328i
If this is to do a toe angel why not just buy a camber tire !!
f30post
