Oil Cap Stuck?
05-31-2013, 08:13 PM | #1 |
Rep 20
Oil Cap Stuck?
For some reason I can't get the oil cap (where you add oil, not the filter housing) off. I don't want to use too much force since I have no idea if it'll break.
Any suggestions or does it just require that much force? |
06-01-2013, 02:51 AM | #2 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
Yes it can get tight - and I find the square shape not as easy to grip as a round one...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-01-2013, 05:22 AM | #3 |
17338
Rep 18,751
You are turning it counter-clockwise, right? Or it may be open but just not flipped up; it does not unscrew all the way off. It turns about 60 degrees and then flips open.
06-01-2013, 08:18 AM | #5 | |
33
Rep 648
06-01-2013, 05:32 PM | #7 |
1086
Rep 1,912
I'm not sure if this situation is unique to me, but mine is hard to open because the engine cover bulges around it a little bit... I have to push the cover down some and then the cap is easy to remove.
06-04-2013, 11:34 AM | #9 |
Rep 17
