Whats my Build Date??
09-18-2007, 11:26 AM | #1 |
M Master
74
Rep 551
-------------------------------------------------------------------------------- Im trying to see if i can order a Quaife LSD but i read that cars with build date March 07 and after have welded diffs and therefore makes the Quaife LSD basically impossible to add... Where can i find on my car the Build Date so i can checkk thanks! |
09-18-2007, 04:34 PM | #7 |
M Master
74
Rep 551
what cats.. and dont hijack my thread.. im trying to find out what my build date is since it doesnt list it.. maybe it coded in the VIN.. please keep ontopic.. thanks
09-18-2007, 06:08 PM | #8 |
46
Rep 1,419
ahahaha man I almost died from laughing anyways, can you make that picture bigger ? I can't see anything
09-18-2007, 07:23 PM | #9 | |
AC
95
Rep 2,387
The date should read mm/yy (01/07 for mine).
Your Supreme Leader
09-18-2007, 09:22 PM | #10 |
7
Rep 292
What do you mean by "welded diffs"? You mean the diff cover is welded on? If BMW did that after March 07 to avoid allowing for aftermarket LSDs to be installed that is just gay.
09-19-2007, 07:12 AM | #11 |
Member
Rep 99
If you go to realoem.com and plug in the last seven digits of your VIN, it will tell you the build date - in your case 8/2006.
http://www.realoem.com/bmw/select.do Note - your car needs to be old enough to be listed there - the current cut off date is 11/06. Lou |
