E92 BMW Performance Suspension - Sway bar bushings
05-18-2013, 11:53 PM | #1 |
Rep 14
Hey guys, I'm hoping someone can help me out. I'm just finishing up the BMW Performance Suspension install and I'm a bit confused about the front sway bar bushings.
The new front bar came with some narrower (glued on?) bushings, however the kit also included a set of new front sway bar bushings in addition. I've attached a couple of pictures to help illustrate. Do you know if I'm supposed to peel off the existing bushings or just use the narrower bushings that are already attached to the bar? Thanks a lot! |
05-19-2013, 08:55 AM | #3 | |
146
Rep 1,160
You have a bar with 4 bushings? Unless 2 part elastomer, you'll have a devil of a time getting the installed bushing off.... What would Obama do? Call the folks you bought it from; inquire. |
05-19-2013, 11:16 AM | #4 |
101
Rep 474
Most likely the bushings are not glued just stuck very very well to the sway-bar. Spray them with penetrating oil and hope for the best. if anything cut them off and replace with the correct bushings. Lube the new ones up with proper grease so they done squeak over time.
05-19-2013, 12:44 PM | #6 |
164
Rep 2,556
+1
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
08-25-2014, 07:53 PM | #7 |
94
Rep 389
Drives: '13 F30 335i MSport
Hey know this thread is really old, but what did you end up doing? I have the same problem!
08-25-2014, 08:14 PM | #8 |
300
Rep 4,040
Drives: 130i coupé ;)
ECS tunning, run part numbers from real OEM : use the one that matches
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
08-25-2014, 08:27 PM | #9 |
Rep 14
08-25-2014, 09:01 PM | #10 |
94
Rep 389
Yea. Found the matching brackets, but at $26/pc. Kinda hard to not cut them off. Any tips for removal?
08-25-2014, 09:03 PM | #11 |
Rep 14
They are a PITA to remove actually. I cut the majority off with a dremel, then used a torch to burn off the remnants. It goes without saying, but use caution if you use the torch approach.
08-25-2014, 09:12 PM | #12 |
94
Rep 389
Thanks!!I figured so when my initial attempt was with a good sized pry bar was futile at best. May just have to pony up the cash for the brackets.
08-13-2015, 04:20 PM | #13 |
15
Rep 188
Hate to bump such an old thread but what brackets did you find that would fit? I had the PS installed over the weekend and we couldn't figure out what to do with the sway bushings as well. I see no instruction on what to do in the BMW instructions document either. Those suckers are stuck on there for good I think.
E46 325i-RIP
E92 335i- BMW PS|M3 Front Arms|FMIC|DPS|ER CP|DCI|JB4|Connect Kit|M Delete |
08-13-2015, 07:38 PM | #14 |
94
Rep 389
sway bar bushings
There are brackets that fit, however at $30+ a piece I opted to cut the bushings off and use my old brackets with new bushings. I used some vice grips and channel locks. They seem really rigid, but aren't that hard to get off. I gripped and pulled the bushing with channel locks and used a straight razor held by the vice grips to cut it off. A heat gun will help soften it up a bit too. lmk if u need anymore help.
2013 GSM 335i MSport
08-13-2015, 08:16 PM | #15 | |
15
Rep 188
View post on imgur.com
E46 325i-RIP
08-13-2015, 09:53 PM | #16 |
94
Rep 389
Sure did. They fit the stock bracket on 328 and 335. Once you rip off the bushing, just take a razor blade and scrape the rest off. If I remember correctly, I think I forced a flathead screwdriver between the sway bar and the bushing to aid the separation.
