AST 5100 installation, please help
05-16-2013, 09:06 AM | #1 |
9
Rep 117
I have just installed a set of AST 5100 but the spring perch is too low. To avoid rubbing on the coilovers, I have to add 15mm spacers but now they rub on the fenders.
Had anyone installed 5100 on e9x with stock top mount? Can anyone help me to set these up correctly by bringing up the perch also avoid rubbing on the adjustable sway mount? Thanks in advance. Springs are AST 7" 60 N/mm with helper. My rims' off set was good with stock suspension. ET35 8.5 with 235 tire below pics are with 15mm spacer and rubbing the fender.
E93 335i Alpine White, 19" Works, PSS, M3 arms, M3 bushings,M3 E93 FSB/E92 RSB, powerflex rear diff bush.
AST 5100 with M3 rear camber arms. GC street plates. |
05-16-2013, 11:03 AM | #3 |
1564
Rep 4,109
Drives: BMW M3
What is your camber up front?
+1 test a smaller spacer, the minimum you can get away with.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
05-16-2013, 11:17 PM | #4 |
9
Rep 117
Evochuck was right. 10mm spacer is the minimum size to avoid rubbing the coil but it will still rub with the fender (I think there is only 5mm between tire and fender originally). Since I already have a 15mm spacer, so I rather invest in a better solution.
CJ421: front camber is -1 with M3 control arms. Thanks for reply.
AST 5100 with M3 rear camber arms. GC street plates. Last edited by e679; 05-17-2013 at 04:58 AM.. |
05-17-2013, 09:53 AM | #5 | |
Power is nothing without control
33
Rep 762
05-17-2013, 10:52 PM | #6 |
9
Rep 117
Lol. Damn, I May need -3 camber to clear.
Will it works by replacing the front spring to 6 inches?
05-19-2013, 06:07 PM | #7 |
30
Rep 468
Coming from a one time AST owner I understand your concern. If your car was like mine the wheel barely rubbed the spring perch. I got enough clearance by simply grinding the spring perch down slightly. I also was not using a help spring as they are not needed with the little amount of stroke the dampers have.
05-20-2013, 12:58 AM | #8 | |
9
Rep 117
I understand the plates are usually an inch shorter than OE top mount I am thinking to buy hyperco helper and 6" front. Buy I afraid 6" cuz insufficient travel.
