05-14-2013, 01:37 AM | #1 |
18
Rep 72
need more power from my 335i sport line , ECU/downpipe/intake - what my best option?
i have the car 4 month
3K miles now BMS , i checked their website they don't offer N55 Stage 2 for F30 yet. i found also those 2: aFe Scorcher http://www.turnermotorsport.com/p-16...-f30-335i.aspx |
05-14-2013, 03:03 AM | #2 |
253
Rep 1,334
BMS does have a stage 2 available for the car if it has a pneumatic boost solenoid rather than the newer electronic one. Dyno numbers are on the "other" site.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
05-14-2013, 08:02 AM | #3 |
1824
Rep 6,979
Drives: 15 F80 M3, 22 G01 X3 30i
What about the M-Performance Power Kit? Everyone here who's installed it (including myself) are giving it very good reviews. Plus, it's a BMW accessory, so there's no warranty hassles.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
05-14-2013, 09:22 AM | #4 | |
58
Rep 218
You might need a new set of tires though. |
05-14-2013, 10:49 AM | #5 | |
18
Rep 72
"JB4 is not currently available for 2012+ F30 335 models. Manual transmission F10 models and F30 models should use the N55 Stage1 tuner" |
05-14-2013, 08:32 PM | #6 | |
7
Rep 72
2013 335i F30 N55
05-14-2013, 09:29 PM | #7 | |
107
Rep 1,997
It really is only beneficial if you want to toss in more aggressive mods with it (at least a DP or I'd say stick with stage 1 as the gains are about the same until you're able to use other maps). If you plan on using DP and have access to E85, etc, Stage 2 will turn your car into a monster. Like the above poster said, stage 1 will give you more gains than anything else out there and is an easy install. |
05-14-2013, 10:47 PM | #8 | |
18
Rep 72
stage 2 sound great , what DP brand/model i should get? also intake , which one? about M-Performance Power Kit: can i get more info about this kit? for first look it's look overpriced for 20 hp only is it come also with intake? thanks |
05-14-2013, 11:01 PM | #9 | |
670
Rep 4,959
Regarding the M Performance Power Kit: Dyno at Post #11 http://www.f30post.com/forums/showthread.php?t=820502 More information, user reviews, etc. - http://www.f30post.com/forums/showthread.php?t=821701
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV Gone: '20 W205 C43 Sedan Gone: '18 W205 C43 Sedan Gone: '13 W204 C63 Sedan |
05-14-2013, 11:49 PM | #10 | |
58
Rep 218
What if i told you i have a JB4 stage 2 hooked up to my engine right now, what if i told you there is such a thing as an upgrade kit from stage 1 to stage 2. All you need is the old boost solenoid. To top it all what if i told you even a stock car will pull like a monster with the stage 2.. The difference is very noticeable from stage 1, especially torque wise. I hate it when people act all smartass, as if they're doing shit to help the OP out. Just stop, all you do is confuse people. |
05-15-2013, 12:16 AM | #11 | |
50
Rep 808
You are the one attempting to look like a smartass. He's just an owner asking questions, you're the dude being the ass here. |
05-15-2013, 10:13 AM | #12 | |
107
Rep 1,997
People will have different opinions on all of this so I'd do some research. For bang for your buck, I'd go with BMS stuff (although when it comes to DPs, there are others that perform just as well, the main difference, it seems, is price and perhaps fitment, but I haven't heard many complaints of any of the major tuners versions). Stage 1 + a DP (let's go with BMS since it's widely used and honestly they all give about the same gain): You'll put down around 335hp at the wheels, which exceeds your 350hp goals at the crank by a fair margin. Not a bad way to spend under $1k and the Stage 1 is easily put on/off in 5 mins or less. Stage 2+ a DP will give you a bit more power for only $150ish more and more flexibility. Map 2 will put you at 355hp at the wheels with a DP. Toss in E85 and you'll be nearing 370hp at the wheels. Stage 2 isn't quite as easy to install/remove as it's not just plug and play (it is but you have to tap into wires instead of just plugging in connectors). As far as the intakes, AFE makes one right now that's pretty pricy, but looks good, not huge gains obviously (it's just an intake so you're probably looking at 10hp'ish) but they are there and probably even more with increased boost. BMS is working on one currently, not sure when it'll be released, but it will probably be a bit cheaper. |
05-15-2013, 02:23 PM | #13 |
58
Rep 218
Lol thats hilarious, my bad! Sorry op, didn't mean to be an ass!
Back on topic then, you should get the stage 2.. Its not THAT hard to install and the gains are pretty amazing. Would you guys do intake or downpipe first? |
05-15-2013, 02:53 PM | #14 |
107
Rep 1,997
Performance wise, DP is a no brainer. You're looking at a good 30hp with no other mod. But obviously it's a bit harder to install and cost a bit more. Intakes don't offer that much of a performance bump for it to be a first mod, unless you're really into the whoossshh sound.
05-15-2013, 03:37 PM | #15 |
70
Rep 1,339
first 2 mods should be JB4 stage 2, and a Catless downpipe I went with ER couldn't be happier with both mods.. next is a catback for me!
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
05-15-2013, 06:08 PM | #16 |
87
Rep 497
JB4 stage 1 with DP throws a code correct?
JB4 stage 2 isn't offered for the 335i manuals still correct? Just want to confirm some stuff cuz it seems like you guys know your stuff with the JB. Thanks
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM F80 DCT (18) - Comp - AW F30 6MT 335i - EBII |
05-15-2013, 08:35 PM | #18 |
253
Rep 1,334
JB4 Stage 2 does work on manuals but you tap into the CAN connectors in a different spot. As of now, the Stage 2 only works with cars with the pneumatic solenoid.
05-15-2013, 08:42 PM | #19 |
107
Rep 1,997
05-16-2013, 01:18 AM | #21 |
18
Rep 72
05-16-2013, 12:20 PM | #22 |
58
Rep 218
http://mmg.photobucket.com/albumview/albums/NICKTENN/A55ADC7D-CE04-4E9D-9BE1-7AE27764E0C6-3309-000001E9B3C7C1B6_zps220667f1.jpg.html
Sorry for the link, the iphone app is not good for posting stuff, The image shows how it looks like, it should be identical. |
