E93 glove compartment lock .. Help !!
05-09-2013, 01:14 PM | #1 |
16
Rep 138
Hi
I just purchased a previously owned 2008 328i convertible and all of a sudden the glove compartment is locked. I can't unlock it with the key fob however I can't figure out why it is stuck on lock. I do not have the key to the glove compartment. HELP !!! |
05-09-2013, 01:21 PM | #2 |
Rep 81
you don't have the key that is clip into your key fob?
05-09-2013, 01:25 PM | #4 |
123
Rep 1,503
05-09-2013, 02:00 PM | #7 |
Ex-Ricer
15
Rep 89
Drives: BSM E93 335i
I have the same problem with mine. It is always locked and I need the key to open it everytime.
05-09-2013, 02:07 PM | #8 |
26
Rep 606
When I took my car in for a recall and got it back my glove box was staying locked. I told them about it and they said it was broken before they did the recall service ^^
They checked it out and found out that they forgot to plug the glove box lock mechanism back in. ^^ |
05-09-2013, 07:01 PM | #11 |
BMWCCA 149159
38
Rep 847
Your problem is the glove box solenoid is broken but can be repaired.
Here you go http://www.bimmerfest.com/forums/sho...d.php?t=660733 |
05-10-2013, 01:14 AM | #12 |
18
Rep 270
Its been a while but I remember playing with a setting so it locks the glovebox and center console when you lock the car doors. That's so you can leave the car parked top down without getting robbed.
Open the master lock in the center and see if that unlocks the glovebox. |
05-10-2013, 10:19 AM | #13 |
BMWCCA 149159
38
Rep 847
That is true there is a sliding switch on the left side of the glove box inside. One setting is valet setting and the other is full access. If the glove box still doesn't unlock once you have checked the setting then the solenoid is toast. Very common on early E93's in fact the only problem I have ever had with my car.
Interestingly of the two DIY fixes one is lubrication and the other a small plastic bumper so the solenoid doesn't over center itseft and get stuck. |
05-13-2013, 06:34 PM | #14 | |
15
Rep 365
09-06-2013, 06:12 PM | #15 |
Rep 1
I had the same thing happen in my 335i conv. I disassembled the glove box doorand found a loose connection on the motor that operates the door latch. Crimped the connector a bit and it works great.
