Valve Stem Warning
09-12-2007, 10:28 AM | #1 |
Rep 40
Drives: Waiting for Coupe
Valve Stem Warning
I have an 07 328 coupe that is 1 year old today. I had BMW roudel valve caps installed before I took the car home. Yesterday I had thr low tire warning and could not remove the caps (no I am not slow). I took the car to the dealer where they said that because the stems are aluminum and the caps are steel they oxodisied together. Took the dealer about 2 hours to get the caps off. Just a warning to check your non-OE caps.
Mark
2007 328, sport pkg, 6spd. manual, RED, black leather (heated), no front plate mount.
I am not saying we should kill the stupid people, we should just remove the warning labels off of everything and let nature take it's course. |
09-12-2007, 11:00 AM | #2 |
8
Rep 283
Interesting. I have used the Roundel valve caps for several months now on my 2007 328 sedan and have not experienced that problem. If anything, they seem a bit loose when I remove them to top off the tire pressure. I got mine from my selling dealer (a "feeebie") and they are an "official" BMW accessory. I'm surprised to hear that BMW would sell a part that fails this way.
I wonder if others have experienced the same problem as you have. |
09-12-2007, 11:00 AM | #3 | |
26
Rep 1,826
Drives: E92 335i
EDIT: yeah, the steel caps on normal plastic/brass stems are fine. The aluminum stems used for direct-TPMS wheels are the issue. I don't think they need to discontinue a long-selling accessory when they come up with a new product that's incompatible, but the dealer should know better than "throwing them in" with a vehicle they'll mess up. Maybe there are new plastic ones? |
09-12-2007, 11:30 AM | #4 |
97
Rep 2,188
It's also scary, the lack of knowledge about this that some stealerships have. I went to my closest one from work to pick up some roundel caps and asked them for the ABS plastic, chrome painted ones rather than the standard metal ones since I had the TPM stems. The parts guy thought I was nuts and asked me "Why would there ever be two different materials for valve stem caps, and what does it have to do with your ABS brakes?!" Idiots. After that I sucked up the 20 minute longer drive to my dealership (Otto's, west chester) and the lady that runs the shop there knew EXACTLY what I needed and we had a good laugh about the other clueless dealer. She was even on-the-ball enough to have the TSB taped right to the counter next to the stems!
09-12-2007, 11:52 AM | #5 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
This wouldnt happen if you check your tire pressure on a weekly basis.
Food for thought.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
09-12-2007, 01:09 PM | #7 |
53
Rep 2,384
Drives: W211 E350 4M MkV GTI 987.2 S
....but the corrosion still takes place continuously, just that you keep removing it by opening it. It will get worse a lot faster in the winter when salty water gets into it. Eventually the aluminum thread on the valve stems will dissolve away (aluminum is more active than iron) then you will have to replace them. At the very least you should put a barrier compound such as anti-seize on the threads if you really want to keep them.
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels |
09-12-2007, 01:13 PM | #9 | |
342
Rep 6,188
13 HD FatBob
