M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      04-29-2013, 05:27 PM   #1
yiango13
Drives: F10 M5 F30 328xi
305/30/20 Pss
As most of you know 305 PSS rears are not available here in US until the fall, but Canada has them! Putting these bad boys on my new hre p40sc when Nate gets then in. Just figured I share this.
F10 M5 Black Sapphire Metallic
E46 M3 Interlagos Blue (retired)
      04-29-2013, 06:14 PM   #2
Tylerstar
Tylerstar's Avatar
69
Drives: Straight Piped F10 M5, GTR
Interesting, wonder if they will fit on the Rear stock 20" wheels? Let us know how they perform! The 295's are just not sticking for me..
      04-29-2013, 10:41 PM   #3
stealth.pilot
Knight Commander
stealth.pilot's Avatar
United Kingdom
557
Drives: 2014 911 Turbo S
Can you also get 275s for the front to keep it balanced?
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      04-29-2013, 10:42 PM   #4
stealth.pilot
Knight Commander
United Kingdom
557
Shouldn't be an issue. The problem is keeping the balance to the front width to avoid creating oversteer.
      04-30-2013, 01:20 AM   #5
Tylerstar
Tylerstar's Avatar
69
Ehhh, yeah your right, definitely don't wanna any more oversteer. Would definitely need the 275's in the front.
      04-30-2013, 04:00 AM   #6
johntomferg
Drives: Formerly drove a 13 F10 M5
What is the difference in the manufacture's contact patch (not just the math off the tires spec 295->305, but the actual spec from manufacture's report).
Is the 305 XL weight rated...?
Link/details please?
      04-30-2013, 04:29 AM   #7
jmh
Internet Crash Test Dummy
jmh's Avatar
Drives: F97 X3MC / F80 M3 / F90 M5
I have been in contact with Michelin and apparently these can be ordered via any authorized Michelin dealer .
The specs are 305/30ZR20/XL 103Y – part number 87598
http://www.michelinman.com/tire-sele...05/30/20/tires
I sent an inquiry to Tirerack and a few others to ask about pricing and availability
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107
      04-30-2013, 08:06 AM   #8
johntomferg
Thanks Jan, it appears to meet the weight rating...
No details on *actual* contact patch size (unless I missed it?)
http://www.michelinman.com/tire-sele...ails#techspecs
      04-30-2013, 08:53 AM   #9
yiango13
I also had Michelin tell me that tire were available in my area however after calling a couple different places no one had it available. I called tirerack and they told me they would not be available till September here in the United States. Nate from IND also told me they wouldnt be available here till the fall. I did a google search and found some Mclaren p1 Forum saying they have them in Canada. Lucky for me my brother in law lives in Canada and ordered them for me! Hes bringing them down here to Indiana this weekend.
      04-30-2013, 08:55 AM   #10
yiango13
Should I go for 275 in the front then? I was just going to reuse stock front tires.
Sorry Pic didn't work the first time.
      04-30-2013, 09:22 AM   #11
johntomferg
Should I go for 275 in the front then? I was just going to reuse stock front tires..
Unless you are driving the car to the limit, it should make very little difference for your day to day life...
The stock tire configurations are as follows:
So the Tread Width value for 19" is:
9.4" / 11.1" or 1:1.181 RATIO
the Tread width value for 20" is:
9.7" / 11.6" or 1:1959 RATIO
Note that the "Section Width" based on YYY/ZZ is the same per the specification chart and why it is important to see the Tread Width value.
That means that within the stock tire options you have about 1.26% variance in the ratio of tread width with the stock options.
You can work the same math backwards from your new rear tire "Tread Width" values to see how much of a variance it creates, but it is possible (if you don't check) that upping the Section Width of the fronts to the next size would put you too far the other way.
I would expect (maybe I have it backwards given Stealth's comments) that the more tread in contact in the back would contribute to understeer, and more tread in contact at the front would contribute to oversteer. (Again) Unless you are driving the car to the limit, it should make very little difference for your day to day life...
For example, you could go to the following tire and gain .8" of Tread Width (overall on the two rears)...and it is still a 295 tire.
(AND for those fighting the Speedometer is off issue, it would make a meaningful difference in that correction.)
      04-30-2013, 09:57 AM   #12
stealth.pilot
Knight Commander
United Kingdom
557
Yes if I was you I would do 275/35/20 in front and 305/30/20 in the back. When the rear is available in the US I will switch too.
I think it is important to keep the relative contact patches similar.
      09-13-2013, 12:20 AM   #13
sultanattar
7
Drives: 2013 f10 M5
Anyone switch to the 305 tires yet?
I am placing an order on BBS CH-R Wheels (20X10.5 ET 35 at the rear) and was wondering if all of that can clear without any poke
      09-13-2013, 07:17 AM   #14
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
Drives: 16 M5, 18 ZL1 1LE, 18 M3
I don't think they are out. I need them in 305/35 for my other car. But no luck.
      09-16-2013, 03:01 PM   #15
Vic55
Vic55's Avatar
19183
Drives: 2023 BMW M8 Competition Coupe
I saw them as "available" last week with TireRack...
http://www.tirerack.com/tires/TireSe...30&diameter=20
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      09-16-2013, 08:30 PM   #16
jmh
jmh's Avatar
Yep have a set in my garage
      10-06-2013, 08:27 PM   #17
Drm5
Puerto Rico
30
Drives: F10 M5 sakhir orange
I am getting mind install in one week.
      10-06-2013, 08:48 PM   #18
yiango13
Are they available in the US now?
      10-07-2013, 08:26 PM   #19
Niko1414
Drives: 720S, s550, S7, 997GT3RS
any issues with springs and going 305's ???
need new rear tires
      10-07-2013, 08:32 PM   #20
yiango13
need new rear tires
No issues. Lowered on H&R springs. 305 give a good amount more traction over 295.
      10-12-2013, 07:37 PM   #21
Charlie Brown
Charlie Brown's Avatar
Drives: F10 M5 Azurite Black
Anyone with a pic of the 305/30 on their car?
      10-13-2013, 12:22 AM   #22
yiango13
Here is a pic with 305 rears
Search this Thread:
Advanced Search
