F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding to enable video thru USB?
proTUNING Freaks
      04-19-2013, 08:16 PM   #1
DXL XLR8
47
Drives: F30
is there a way to code the car to enable video playback thru usb?
      04-20-2013, 10:50 AM   #2
Chris@codemybimmer
BimmerPost Supporting Vendor
Chris@codemybimmer's Avatar
171
Drives: AW F30 328i Xdrive
i believe there is
but only for NBT
      04-20-2013, 11:25 AM   #3
HypoGXII
Drives: F30 335i
Originally Posted by 1lyfe View Post
i believe there is
but only for NBT
How do you check whether you have NBT or not?
      04-20-2013, 02:29 PM   #4
Chris@codemybimmer
171
NBT is the new navi system that comes with hybrid 3 or late 2013 - 2014 models
      04-24-2013, 09:04 AM   #5
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
is this confirmed? i'd like to code mine as well
      04-24-2013, 09:32 AM   #6
kon
Singapore
21
Drives: F30 310i > G20 310i
When you read your vehicle SVT through esys, if you see HU_CIC then you have the old headunit, USB video is not supported, only ipod video (provided also you have BMW Apps, option 6NR)
If you see HU_NBT, then you have the new unit, at which case, you will be able to enable video via USB as well as enabling the unit to play video using additional codec (think MKV and stuff), plus storing the video on the hard-drive. And not only that, you can also enable wifi hotspot and stream video from your phone to the headunit
      04-24-2013, 10:35 AM   #7
ad78
Yr1OfD1
ad78's Avatar
Ok I have HU_CIC but I do have BMW apps and professional nav
      10-06-2014, 10:23 AM   #8
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Does anyone know the code ?!!
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
f30post
