2 times now long cranks upon ignition...fuel pump?
09-09-2007, 02:57 PM | #1 |
83
Rep 793
I have a mid June built car with 1600 miles on it (700 of those in euroope) and two times now....upon starting I hear the engine cranking over several times before car turns on..... can this be a fuel pump going bad (early symptoms)?
I noice there aren't that many fuel pump theads anymore...did bmw start using a different pump at a certain time in the build cycle? I just don't want to get stranded somewhere.
Now: '11 BMW X5 xDrive35i
Then: '07 X3 3.0si '07 335xi '06 Audi A4 2.0T Quattro |
09-09-2007, 09:15 PM | #3 | |
Member
Rep 47
So you may want to make sure you didn't get some bad gas some place...I suspect that's what happened to me. My car starts every time now right off the bat and immediately idles right at 600-700 rpms perfectly.
e90 335xi / 6MT / titanium silver / black leather / premium / cold weather / sport / iPod
09-09-2007, 09:30 PM | #4 |
83
Rep 793
I got gas at the same place I always do...I'll see what happens 2morrow when I get a different brand of gas.... say I get stranded though... how far will BMW assist tow my car? my dealer is 33 miles away and by far not the nearest bmw dealership... but probably the only one that will give me a loaner...
09-09-2007, 10:11 PM | #5 | |
1469
Rep 3,553
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
09-09-2007, 10:23 PM | #6 |
83
Rep 793
DiFeo BMW... hell I'll go closer if someone has a good service dept and will give a loaner
09-11-2007, 01:00 AM | #7 | |
1469
Rep 3,553
If your vehicle should break down while covered under warranty or require towing after an accident or collision, it will be transported to the nearest authorized BMW center. You may also elect to have your BMW towed to the BMW center of your choice, provided that the center is within a 50-mile radius of the closest center. you should be good to go... i got my 335i from difeo too.
09-11-2007, 07:40 AM | #8 |
Rep 87
Drives: 07 335i Sedan
I'm scheduling an appointment today. All the sudden, the crank times are much longer than before. Once the car gets going, I don't notice any other issues. If it is a fuel pump problem, I'd obviously like to address it prior to a complete meltdown...
'07 335i Sedan Titanium Silver, Black Dakota, Burl Walnut Trim, Premium Package, Cold Weather Package, Nav/iDrive, Comfort Access, iPod Adapter, Sirius |
09-11-2007, 07:40 PM | #9 |
83
Rep 793
thanks for the info guys... made an appt today but the first one available with a bmw loaner was oct 6 hope it's ok till then.... I dont want to be damaging the starter with the long cranks though...
09-11-2007, 07:43 PM | #10 |
133
Rep 4,764
Mine consitently starts right up when the engine is cold or only turned off for a few minutes (like when pumping gas). Any time it's turned off for 45 minutes to 3 hours I have a 2 second crank time.
Will prob wait a few weeks and then make an appointment. |
09-11-2007, 07:54 PM | #11 |
83
Rep 793
is there any way to check the fuel pressure through some hidden i-drive menu to see if that actually what the prob is?
09-11-2007, 08:12 PM | #12 |
Drives Smart
54
Rep 2,393
No but if it does go bad you will get a Limp Home mode warning or Low power or w/e...btw what gas do you use?....If its Shell then good but if its not top tier that could be the culprit
08 BMW ///M5 Space Gray/Black 6 speed Engine: RPi GTS exhaust, RPi Scoops, Carbon Filter Delete Exterior: Glossy Black Kidneys, LUX V3, OEM LED License Plate light, Bruce License Plate Adapter |
09-12-2007, 07:55 PM | #13 |
83
Rep 793
I use BP most of the Time.... tried Exxon since the problem started....and monday filled up wit Quickstop gas.... always 93 octane...same problem persists.....so Im sure it's not the gas
09-12-2007, 08:33 PM | #14 |
Rep 87
The thing that is really strange about this is that sometimes it starts immediately. For the last 2 weeks or so, it would crank 4 or 5 seconds every time I started the car.
But today, it started immediately every time. I took the car to and from work and then took my son to guitar lessons and then ran a couple other errands... Strange. I am taking the car in tomorrow. At this point, I wish it were a more consistent problem just so it would be easier for them to diagnose any problem. I would hate for it to work perfectly tomorrow, and then all the sudden the long crank times come back in a couple days or so.
09-14-2007, 02:25 PM | #15 | |
Drives Smart
54
Rep 2,393
QuikTrip Chevron Conoco Phillips 76 Shell
09-14-2007, 02:36 PM | #16 |
539
Rep 18,123
It's not the gas.
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
09-14-2007, 07:13 PM | #18 |
15
Rep 949
+1
My money is on the pump. If you search the fuel pump failure threads, they all start out with someone getting the long crank. What happens after seems to vary in the posts; some of them crap out immediately (and have left people stranded) and some take a while to die.
E92 335i Coupe Delivered 5.30.07 | Black Sapphire | Black Dakota | Grey Poplar | OEM 230 19" Wheels | Michelin PS2s | GP Thunder 8500K Angels
__________________________________________________ __________ |
