04-12-2013, 09:49 PM | #1 |
56
Rep 286
Combox Media vs 6NR ConnectedDrive Retrofit
Hi,
I'm getting Combox Media Retrofit done on my 2012 320i through bimmerretrofit. Now i came across bimmer-tech and they have these two options. Am i correct in assuming, if Combox is installed I'm able to activate ConnectedDrive by coding? Thank |
04-13-2013, 08:22 PM | #2 | |
10340
Rep 40,310
Drives: 2018 Alpina B6 650ix GC
The $489.45 ConnectedDrive Retorfit requires Combox, and it adds 6NR BMW Apps. Unlike the Stock 6NR, which requires the 6NF Base Plate and has an FBAS Video Connection from the 6NF Base Plate to the back of the CIC, the ConnectedDrive Retorfit instead replaces the 6FL center armrest USB Aux-In Connector with a USB AV-In Connector from the Mini Cooper, and makes the FBAS Video Connection from it to the back of the CIC. Since ISTA/P 2.43, 6NR BMW Apps also requires the optional $207.53 9C FSC Code Imported and Activated in the Head Unit.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
05-07-2013, 01:54 AM | #3 | |
Rep 67
05-07-2013, 12:41 PM | #4 |
Rep 11
Additional Newbiw Q related to ComboMedia reprog
Hello,
After some long savings, finally managed to get a June-2012 F30 with low mileage, imported from Germany ... Now, I would love to get introduced to the interesting world coding, but after reading all the different threats on this forum I'm somewhat lost. The main option I would love to have enabled, is the Office functionality and if possible BT Audio Streaming. The car is equipped with CUC, NAV Prof, Combo Media box(BN2010 BE B007),BT(S6NHA), Voice D, HUD, HK Audio, BMW Live, etc. Again what is unfortunate missing are Office and Audio Streaming. Trough a forum member already tried to enable the Office option in E-SYS. ,but this is only displays the Phone Address book. Does anyone perhaps have a good doc or a workflow how to enable/re-program the existing Combo unit and get Office & if possible BT Audio streaming? Much Appreciated Newbie M.... |
05-07-2013, 03:57 PM | #5 | |
288
Rep 1,892
What did the coder do to try to enable office? Since you have 6NH, you should be able to change it to 6NK and VO code the HU_CIC and CMB_MEDIA and have all of the Office functions, BT streaming (A2DP), album art, etc. I've done this on 2 F30's so far with excellent results. |
05-07-2013, 04:54 PM | #6 |
10340
Rep 40,310
Sorry, but I don't. I never retrofitted the USB Port as I have no use for Video and iPod Out GUI. I just added the 9C FSC Code and coded 6NR for the Music Apps like Pandora.
05-11-2013, 08:53 AM | #7 |
Rep 11
Error Processing XML data file for CAF
Hello Team,
Just got my cable trough the mail and followed the Coding steps. After reading the CAFD files I got on one file a XML error (see below). DSC [29] [VIN] - CAFD_000009EF_000_019_001 cafed 000009ef-000_019_001 Felher: NCD read from ECU "ECUIdLDSC_0x29" for CAF "cafd_000009ef-000_019_001"failed! [C069] Error processing XML data [1660] - SYSTEM ERROR Does anyone have an idea how I can fix this error? Many Thanks, M. |
05-11-2013, 09:25 AM | #8 | |
10340
Rep 40,310
What is your current I-Step? http://www.f30post.com/forums/showpo...postcount=1403
05-11-2013, 04:27 PM | #9 | |
Rep 11
Used E-sys version is V3.22.5 build 34057 Specified within E-sys Info PSdZData V4.6.0 - 20120328-1654 Copied/Used PSdZ data files are: V49.2 Current I-Step is: F020-12-11-502 M Thanks, M. |
05-11-2013, 08:58 PM | #10 | |
10340
Rep 40,310
Is it only the DSC module where you get this error, or does error occur on other modules too?
05-12-2013, 02:57 AM | #11 | |
Rep 11
Additional question, what is the DSC module purpose, as I don't know if I would need it from programming perspective? M Thanks, M. |
05-12-2013, 08:44 AM | #12 | |
10340
Rep 40,310
I would try E-Sys 3.22.5 and 49.3 PSdZData.
06-09-2013, 04:51 AM | #13 | |
Rep 11
BMW Apps Retrofit (FA config ???)
Besides the HW retrofit components & req. FSC code, what would be other requirements from coding side? In other words, how should the FA list look like to enable BMW Apps, Internet and BMW Live? Tried to add 6NR to my FA list but this isn't displaying the BMW Apps menu. Do see BMW Live and Internet in the Menu. Appreciate you valuable input on this, B Regards, Martin |
06-09-2013, 11:58 AM | #14 | |
10340
Rep 40,310
CONNECTED_DRIVE = aktiv - Replaces "BMW Assist" on the main iDrive menu, with "ConnectedDrive", with "BMW Assist" becoming a submenu item of "ConnectedDrive". A4A_REMOTE_APPS = aktiv - Adds "Apps" under Main Menu = > Connected Drive with Sub Menu BMW Apps (Facebook, Twitter, Web Radio). If 6NR is in the VO, or enabling this with no valid 6NR FSC Code, it will override CONNECTED_DRIVE = aktiv setting and ConnectedDrive on Main Menu will revert back to BMW Assist. ONLINE_BROWSER = xxxx - Adds "BMW Online" under ConnectedDrive => BMW Assist and where xxxx is: ONLINE_BROWSER_LIVE = aktiv - Replaces "BMW Online" with "BMW Live" under ConnectedDrive => BMW Assist.
06-09-2013, 02:21 PM | #15 | |
BimmerPost Supporting Vendor
663
Rep 1,975
Drives: 2020 G20 320i M Sport
I think I've given up on the ConnectedDrive features on my F30; tried quite a few VO cobinations and still no luck. Made a lot of FDL changes on HU_CIC, enabled PAN, enabled DUN, enabled BT Data service etc and same result. I can never seem to get the Bluetooth Data Transfer profile to show up. Maybe it's the combox we have since its media features were never meant to be enabled if you don't have BMW Assist. |
06-09-2013, 02:24 PM | #16 | |
10340
Rep 40,310
06-09-2013, 02:30 PM | #17 | |
663
Rep 1,975
I added 6AL and 614 to the VO and coded CMB_MEDIA and HU_CIC and this added BMW Live and Internet as submenus under BMW Assist but without Bluetooth Data Transfer service, they can't be used. I've tried at least five different mobile phones with DUN and PAN and same thing. |
06-09-2013, 02:35 PM | #18 | |
10340
Rep 40,310
06-09-2013, 02:38 PM | #19 |
663
Rep 1,975
06-09-2013, 02:38 PM | #20 |
10340
Rep 40,310
Yes, it is.
05-21-2014, 01:50 PM | #22 |
10340
Rep 40,310
