Ground Control Suspension
04-05-2013, 08:56 PM | #1 |
113
Rep 739
review coming soon 440f 700r spring rates street camber plates m3 rear wishbones |
04-06-2013, 12:27 AM | #2 |
146
Rep 1,160
04-06-2013, 02:52 AM | #3 | |
113
Rep 739
Jb4 g5 iso w/ backend e85 flash running map 5 E60 Alpina auto trans tune Walbro 455lph DCI w/ ram air scoops BMS oil catch can BMS Oil thermostat bypass VRSF downpipes VRSF 7" intercooler Straight piped exhaust with vibrant resonators Wavetrac lsd (will review this as well) m3 front suspension components VMR VB3 18x8.5 255 front 18x9.5 275 rear toyo r888 Zimmerman coated rotors Type 200 Brake fluid EBC red stuff Brake pads Motul power racing 300v 5w30 I think i am switching to Mobil 1 0w40 (I can change my oil 3 times for the price of Motul) Water Wetter and factory coolant Front alumalite splitter Bmw performance cf rear spoiler M3 front bumper w/ custom brake ducts Motorsport hardware 82mm studs w/ 2 piece race lugs w/ locks (These guys are great) Some weight reduction car weighs 3400lbs without me in with a 1/2 tank of gas 47.8% weight distribution without me in the car with me is right at 50.1% i think i may be forgetting somethings but thats the main stuff
04-06-2013, 05:35 AM | #4 |
146
Rep 1,160
04-06-2013, 11:28 AM | #5 |
113
Rep 739
front sway is an e93 m3 sway bar no bar in the rear and no rear subframe bushings however i think i am going to order soild aluminum subframe bushings from turner
04-06-2013, 07:32 PM | #6 |
50
Rep 211
Can't wait for the review! I'm looking to get the same kit for my 135i.
Could you do me a favor and measure the GC struts for me? From the lip where it sits in the knuckle to right where shaft begins. I understand GC are a bit shorter than OE or off the shelf Koni. Also let me know if those camber plates are as quiet as stock. I'm currently running 400/700 springs with TCK kit and the ride is extremely comfortable. Did not like noisy camber plates so I switched to stock strut mounts. However, stock mounts raised the ride height more than I liked and I'm almost out of bump travel to lower more. Hence, me looking into shorter strut options such as GC offers. |
04-06-2013, 10:21 PM | #7 |
300
Rep 4,040
Drives: 130i coupé ;)
Subscribed
Which version of the school/street kit is this??
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
anotherchengman10.50 |
04-06-2013, 11:34 PM | #8 |
113
Rep 739
this is the kit http://www.ground-control-store.com/.../II=903/CA=179
single adjustable 440f 700r with street camber plates rear m3 control arms etc same kit as above |
04-07-2013, 11:21 AM | #9 | |
146
Rep 1,160
You like a firm ride. But w/LSD + Street/School, you really, really need that rear M sway. No biggie to install. . Last edited by CALWATERBOY; 04-07-2013 at 11:27 AM.. |
04-07-2013, 11:24 AM | #10 | |
146
Rep 1,160
04-07-2013, 05:07 PM | #11 |
158
Rep 1,288
Drives: 2014 435iX, FBO
wow, good for you !
Subscribed.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
04-07-2013, 07:34 PM | #12 |
11
Rep 93
04-07-2013, 07:54 PM | #13 |
38
Rep 864
Drives: '08 E92 335i
I'd wait until you do the LSD and subframe bushings to do the swaybars... the subframe has to drop at least a bit to do the rear sway, better to just do it all at once. I got my diff/swaybars/subframe & diff bushings all at once.
04-08-2013, 10:49 AM | #14 | |
158
Rep 1,288
Dinan did NOT recommend that I do the rear sway until I got the LSD done at the same time because your traction goes DOWN apparently. Do them all at the same time and save money as the whole rear end comes down.
04-08-2013, 06:53 PM | #15 |
164
Rep 2,556
Why does he need an M3 rear roll bar with 700 lb springs?
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
04-08-2013, 07:02 PM | #16 |
113
Rep 739
Honestly i do not think ill really ever go with an upgraded rear sway unless i heavily upgrade the front and then ill do a small rear i dont think these cars like rear sway bars even with an lsd. I am going to wait to do the review until i have the diff in whihc will be the end of this week
04-08-2013, 07:23 PM | #17 |
164
Rep 2,556
^ That's what I've heard from track drivers
04-09-2013, 06:53 AM | #19 | |
Rep 79
Subscribed...
Does GC use Koni external adjustable rear shocks (adjust rear rebound without removing from the car?) Quote:
- Thx
2016 BMW S1000RR - BrenTuning - Akrapovic - Attack - Rizoma - Graves 2009 E92 335I / 6MT |
04-09-2013, 07:04 AM | #20 |
50
Rep 211
I asked the OP to measure because I didn't know However, I did call Jay@GC and he told me they are 12mm shorter. Those struts along with lower height camber plates, a lower ride height is possible while retaining normal bump travel.
04-09-2013, 07:08 AM | #22 |
146
Rep 1,160
