04-05-2013, 08:53 PM | #1 |
62
Rep 664
Lighting Package Retrofit?
Hi everyone!
Last year when I ordered my 2012 328i I didn't want to order the lighting package because it required premium package and then some ridiculous additional cost. Now that it's available as a $900 stand alone option is it possible to have it added to my car now? Thanks! |
04-05-2013, 08:55 PM | #2 |
263
Rep 1,130
Drives: '16 340i AW MSport
Not for $900 or anything close, more like the cost of the premium package ++, seems like its around ~$3500+ to do it oem.
You are better off waiting for aftermarket. |
04-05-2013, 08:56 PM | #3 |
62
Rep 664
So it is possible to have it done at my dealership's service department? I can't do it aftermarket since the car is leased.
04-05-2013, 08:58 PM | #4 |
263
Rep 1,130
04-05-2013, 08:59 PM | #5 | |
62
Rep 664
Any idea what these are? http://www.shopbmwusa.com/PRODUCT/39...CE-LIGHT-BULBS Last edited by Ryan9095; 04-05-2013 at 09:12 PM.. |
04-06-2013, 12:04 AM | #6 | |
Rep 105
Drives: F30 328i Sportline
There are a few threads about headlight changes from standard to Xenon with LED DRL's. Not sure if anyone has actually done it yet but it seems extremely expensive and from what I've read, not all dealers believe it can be done. Your best bet may be to wait out your lease or give the aftermarket ones a go when they're available (apparently June-ish) and hold on to your OG headlights and replace when the lease is up.
F30 328i Sportline
Stock, for now... |
04-06-2013, 12:25 AM | #7 |
*Bimmerpost Plasti Dip Guru*
83
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
It is possible, but be read to shell out a lot of big bucks!
Never cheep out on the xenon\ lightning package, alot of people regretted this.
04-06-2013, 12:35 AM | #8 |
Estorilblau Member
27
Rep 252
If the only issue is with the color of the lights, just get aftermarket bulbs.
If you want the higher light output and the adaptive lighting feature, it's just not going to happen unless you do a full retrofit. Frankly, it's just not worth the cost IMO. |
04-06-2013, 09:44 AM | #9 |
62
Rep 664
Thank you all for the responses! I'm really just interested in having the white light you get from the xenon. Is it easy to change the bulb? I'd want to save the current standard ones since I need to return the car factory when my lease expires. Also, how do I know what brand/color to get?
04-06-2013, 09:55 AM | #10 | |
263
Rep 1,130
As far as color yes, changing bulbs will get you white light. The best will be a conversion type like these H7R's: http://www.ebay.com/itm/35W-Car-HID-...-/250990041968 Little more work than just bulb changes, but you'll get a similar look, just not as nice as OEM. Or you can change bulbs and use something like this which will make your car look like the pic below: http://www.ebay.com/itm/6000K-Xenon-...db63dd&vxp=mtr Hope that Helps |
04-06-2013, 10:02 AM | #11 | |
50
Rep 1,730
It seems strange that so many 328's on BMW dealer lots don't have the lighting package, you would think they'd get a clue but maybe your average consumer just thinks it's a waste. The other problem is people don't test drive the car at night and/or never see it turned on from the outside. I'm surprised SA's don't try to more aggressively push this option, give them a walk around and show the comparison, easy $900 extra...
UNDRSTR
04-06-2013, 10:04 AM | #12 |
50
Rep 1,730
That actually doesn't look to bad! The lack of DRL outlines is unfortunate, but for what I guess is a $60 upgrade that's night and day (pun intended).
UNDRSTR
04-06-2013, 10:10 AM | #13 | |
62
Rep 664
You are the best man! Thank you so much for finding these! Just for clarification sake if I go with "option 2" I'm literally just exchanging the bulb whereas the H7R (which is better?) will be more work? Also, do I have to worry about the car being able to handle the increase amps? Sorry for all the questions... never done anything like this before! |
04-06-2013, 04:20 PM | #14 |
19
Rep 428
A few words of caution before you do anything, I've gone through this 2.5 years ago; though forums, dealers, mechanics and other BMW owners. I decided not do anything, because it's either cost prohibitive or risky or would not achieve results I desire: quality and cost effective replacement/upgrade.
Please go to the lighting forums and read other more specific posts, as it was suggested before. The issue has been discussed many many times and there are a couple of questions that you have to have a very good answer for before you do anything on a brand new car: 1. How does this mod affect your factory warranty? Any unauthorized mods to your car may completely invalidate your car's warranty. And for a leased car, it may also violate a leasing agreement (please check your documents). 2. Will putting this HID kit or just high power bulbs that exceed factory specifications and were not specifically designed for the bulb housing, give you desired results in terms of a) color b) light intensity/distance c) safe focus/angle for you and other drivers d) may be missing a few more items here 3. Is your car's lighting assembly sufficient to withstand extra current and/or heat that these mods may generate? In my case, I tried to put just "whiter" halogen philips bulbs, it did not produce a noticeable difference to me. Not to say that other people said it was enough for them. My dealer said he could install factory lights on my car for $4,000. It did not make a financial sense to me. The bottom line, I have not seen anything on this market today that is as good looking as efficient and as functional as OEM Xenon Adaptive lights that you can get even close to $900. That's my single biggest regret about my car, and I will not make that mistake again. |
04-07-2013, 02:50 PM | #15 | |
32
Rep 175
04-07-2013, 03:39 PM | #16 | |
62
Rep 664
04-07-2013, 09:04 PM | #17 | |
32
Rep 175
