I have 2 solutions and need some input
03-21-2013, 01:42 PM | #1 |
20
Rep 131
I have Z4 35i so I do not have so many options.
Down pipe is kinda expensive because they only have AR make it to fit e89. Here is 2 solutions that I have. 1. keep the first cat , delete the second cats (straight pipe) , delete the mufflers. this option I don't really spend money much safe a lot of money. 2. get AR catless (non resonate) down pipe , delete secondary cats , keep the muffler or after market muffler. This option will cost me 3k plus. So... my question is speaking about performance wise (flow and back pressure balh blah) not about sound, Do you guy think it has a $3k different in the performance ? How are these 2 solution has in term of flow and back pressure that engine needs. BTW my car has: FMIC , Charge pipe , DCI , High boost map on ProCede V5 thank you guys.
'09 Z4 35i on the way of build
'06 997s built motor from Vision Motorsport 421WHP N/A '96 Skyline R33 GTS stock trying to register it. '99 Subaru Impreza 2.2 JE pistons , HKS rods , Jun cam 272 / 272, Greddy T78 32D , Sard 1000cc Inj., Tein and Tomei SQ trans , 10.21sec Last edited by GooDy151; 03-21-2013 at 02:02 PM.. |
03-21-2013, 02:14 PM | #2 |
Instagram: @Marcadelic
243
Rep 2,697
deleting your secondary and mufflers will not give you any noticeable gains, it'll just make the car A LOT louder.
If you want to increase hp you definitely need to get catless dp's, but you have to justify if it's worth the money to you. 3k's a lot, it should be more like 1k total, leave the secondaries and delete the muffler if you want it loud.
| New: 2018 F80 M3 | Old: 335i / 335is | Instagram: Marcadelic | |
03-21-2013, 02:36 PM | #3 |
nsomneeak
39
Rep 501
Yeah, $3k is about 3x too much; you can buy them straight from AR for a bit less than $1k.
RB Turbos w/ N20 TMAP Sensor | 93 Octane Protune by Cobb Plano | xHP Stage 3 | BMS DCI | STETT CP | Forge DVs | RB PCV | Helix FMIC | CP-E Catted DPs | Walbro 450 | Bilstein B12 | M3 Control Arms | Defiv Lockdown Kit | BBS CH | Michelin A/S 3+ Hixson BMW of Monroe, LA - Shady Dealer | |
03-21-2013, 03:07 PM | #5 |
243
Rep 2,697
ive never heard of anyone doing that on our cars
03-21-2013, 03:11 PM | #6 |
41
Rep 823
a lot of people have.. i personally don't know many who have, but i do know someone who did it on their 135... to run more boost the main purpose of modifying the exhaust is to delete the restriction... the restriction is the cat.. delete it..
03-21-2013, 03:58 PM | #7 |
20
Rep 131
I mean $900 for AR + $1500-$2500 for after mater exhaust (muffler)
'06 997s built motor from Vision Motorsport 421WHP N/A '96 Skyline R33 GTS stock trying to register it. '99 Subaru Impreza 2.2 JE pistons , HKS rods , Jun cam 272 / 272, Greddy T78 32D , Sard 1000cc Inj., Tein and Tomei SQ trans , 10.21sec |
03-21-2013, 04:04 PM | #8 |
20
Rep 131
It could be done but a little complicate to get in there for exhaust shop. Meaning labor will cost half of the price of AR.
03-21-2013, 04:08 PM | #9 | |
41
Rep 823
If you are paying more than 250 for labor on DPs you are getting ripped off.. I wouldn't even pay that.. |
03-21-2013, 04:20 PM | #11 | |
20
Rep 131
but his worker look at the down pipe and the pull up alldata time to remove it and it was like 6hr on one of them and 2.5 on another on on my Z4. And he didn't wanna do it his shop just do cat replacement for daily driver car. Money is not super big issue if it worth the price. If main cat has more restriction than secondary cat then I'll have to think about getting AR. and thank you for comment on my garage
03-21-2013, 04:34 PM | #12 |
41
Rep 823
if your main concern is being able to run more boost (based on the cars in your sig im assuming so) go with a catless DP and leave the rest alone for the time being.. Your buddy can always hack out the rest as you mentioned. muffler delete will likely be too loud, but if you are down with running straight pipes go for it.. my recommendation would be replacing the DPs with catless ones and gutting your secondary cats.
03-21-2013, 05:40 PM | #13 | |
20
Rep 131
03-21-2013, 05:50 PM | #14 |
580
Rep 4,393
I think that's what they mean. My car is at the shop right now getting secondary cats deleted. Cut it out and do straight pipe. I'll be VRSF catless DP's then secondary cat delete. Otherwise stock e90 exhaust with resonators
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ |
03-21-2013, 06:43 PM | #15 |
48
Rep 1,010
Yeah for performance.. Catless downpipes.. Merely deleting the cat from the stock down pipes will affect back pressure and will not perform as well as cat less downpipes..
You should have plenty of room for catless downpipes.. Maybe contact BMS or VRSF to see if you can use their dps.. Much cheaper than AR
2008 335xi Jet Black//Coral Red VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash Apex EC-7//Michelin PSS//Dinan CAI |
03-21-2013, 07:01 PM | #16 |
3441
Rep 79,211
The main cat is the biggest restriction and the biggest adder of power.
Why dont you just pull the stock downpipes and have your shop gut them? That's the least expensive route and the most HP gain. |
03-21-2013, 07:25 PM | #17 | |
I even mod my cereal
247
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
OP, go with the AR DP....they make great pipes that fit well and make good power.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser Last edited by bigdaddycane; 03-21-2013 at 07:32 PM.. |
03-21-2013, 07:34 PM | #18 |
20
Rep 131
Thanks for all input guys !! Cheers
03-21-2013, 10:46 PM | #19 | |
41
Rep 823
03-21-2013, 10:55 PM | #20 | |
41
Rep 823
Can you hear/see the difference if a car has an AR pipe vs a gutted stock dp? ...Which depending on where you live is getting murdered like everything else under your car daily or seasonally |
03-22-2013, 12:03 AM | #21 |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
In regard to gutting your stock downpipes cats, you may want to consider how much a new set of OEM primary cats cost. You're going to need to install them again some day and if you have them in a box in your garage, it's going to be a lot cheaper than buying new ones again before selling your car or trying to pass a smog test if you've failed after the first try.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
03-22-2013, 05:14 AM | #22 |
314
Rep 3,262
I did on mine It's cheap and the power gains are the same. They just don't look very nice, but they work:
http://www.e90post.com/forums/showthread.php?t=451224
