Rear brake advice!
03-21-2013, 09:16 AM | #1 |
153
Rep 770
Rear brake advice!
So my rear brakes are due soon, and BMW is quoting me about 750.. So I will be buying all the parts and finding a shop to do it. Few questions:
1) where is the best place to buy the cheapest rear brake parts? (Everything I need except labor obviously) 2) should I stick with OEM rotors and OEM brake pads? Any consensus on ceramic vs OEM pads? Should I switch to ceramic for less brake dust? 3) the squeaking at low speeds...... Has it been decided that the cause is the brake sensor? What should I tell the shop so that my rear brakes don't squeak anymore when taking off??? 4) fair price for rear brake job, assuming I supply all parts?? Thanks!!! |
03-21-2013, 09:22 AM | #2 |
25
Rep 561
Contact Kevin@R1 Concepts. They do a great job with customer service and have competitive pricing. If you're looking for strictly OEM replacement, try Tischer.
PH: (616) 914-6677 FAX: (305) 255-5446 Contact me for exclusive forum and wholesale pricing! Email: Sean@Forgeddistributing.com Site: http://www.forgeddistributing.com/ |
03-21-2013, 09:31 AM | #3 |
22
Rep 1,083
Drives: 2021 M2C 6MT
Garage List My garage spot [0.00]
07/07 BMW 335xi [8.50] 2001 Honda CBR600F4i [0.00] 2007 Husqvarna SM610 [0.00] 2004 Chevy Tahoe Z71 [0.00] 2005 Harley Davidso ... [0.00] 2007.9 335xi [6.50] |
Im usually all for DIY but with brakes on my DD I didn't have the luxury of a day or two to work on them. I just did my rears yesterday at the stealer and found that the reputable independents are just $50-60 per axle cheaper. Fluid flush was the same at $140.
Pit them against each other and strike your best deal. The Indy also doesn't have a rental car for me and that made it ultra convenient.
2021 BMW M2 Competition, BSM, Exec Pkg, 6MT
GONE:07/07 E90 335xi SG Black Dakota|Alum|ZSP|2AB|ZPP|ZCW|Nav|CA|6FL|PDC| Blacklines|3M Summers: 235/40/18 265/35/18 Hankook Ventus V12 on VMR 701s A/S: 225/40/18 255/35/18 Pirelli PZero Nero M+S on OEM 162s |
03-21-2013, 09:34 AM | #4 |
13
Rep 110
If you just need to replace the pads and the sensor, DIY is not much more difficult than an oil and filter change. OEM pads and a sensor will run just over $100 from Tischer.
03-21-2013, 09:50 AM | #5 |
153
Rep 770
I think the rotors need to be replaced too. I'm planning on buying the parts and taking it to a shop for just the labor... Should be considerable cheaper than 750 (remember this is just for rear brakes, not front and rear)
03-21-2013, 10:09 AM | #7 |
74
Rep 2,848
365 from tischer for the rear kit, pads rotors, sensor all OEM. Not bad at all
http://www.getbmwparts.com/partlocat...catalogid=4462 |
03-21-2013, 10:13 AM | #8 | |
153
Rep 770
Thanks benzo for the pricing |
03-21-2013, 10:17 AM | #9 | |
66
Rep 850
I put them on all my bmw's great grabbing power, no fade and barley any dust. They claim better stopping power than oem also. Just make sure you follow the directions on the box for bedding them in. Very simple. I have them on the front of my 335 now, front wheels super clean, rears are gross after a week. Dont go back to OEM pads they suck |
03-21-2013, 10:20 AM | #10 | ||
153
Rep 770
Also, has anyone solved the squeaking problem?? |
03-21-2013, 10:25 AM | #12 | |
66
Rep 850
Ive been running HPS fronts and oem rears for the last 15,000 miles. No issues. |
03-21-2013, 11:04 AM | #13 |
Rep 108
I just had my rear brakes replaced (pads, rotors & sensors) for ~464 @ West German in Ft. Washington PA; just outside of Philly. Mine is a 328xi so the pricing might be a bit more for a 335 but thought that was a decent deal for parts & install. They gave me a car too (X1), PM me & I can connect w/ my service advisor. My OEM pads lasted from 54K when i bought it CPO to ~84K
03-21-2013, 11:24 AM | #15 |
66
Rep 850
Fair labor charge is hard to determine. I would not take it to a Midas,Firestone, Sears, Goodyear or any type of a joke place like that. I'm not saying they are bad techs but sometimes you get young techs etc. Most shops will get angry that you bring your own parts and jack up the price. A good tech can have those brakes changed in under an hour (as long as the ebrakes release the rotors easily). Make sure you have them do the bedding info on the box. I don't trust anyone enough thats why I do it myself. Im sure you can find a forum member who will help you do them if you never have before. Good reason to buy some tools instead of using that money to pay someone else.
03-21-2013, 11:32 AM | #16 | |
153
Rep 770
Are these the same as the ones from ECS? They're really cheap from HPF http://www.horsepowerfreaks.com/partdetails/Hawk/Brakes/Brake_Pads/HPS_Performance_Street/19706//BMW/335i |
03-21-2013, 11:42 AM | #17 |
210
Rep 1,161
@ Helix in Philly:
Hawk HPS rears: $83.13 Cross Drilled Centric rotors: $98.13/ea Sensor about $25 Labor $127.50 Total installed: $432 plus tax. |
03-21-2013, 11:52 AM | #18 | |
66
Rep 850
Good price! I had good luck with centric rotors on my 545! |
03-21-2013, 12:05 PM | #19 |
Rep 150
When it came time to do my brakes, I tried to weigh my options between performance, price, dusting, and noise.
Believe it or not, this is very difficult to do. There is no golden setup that has the best of all worlds. For my rear brakes, I went with this setup: Rotors: Centric Premium with EZ-Coating http://www.amazon.com/Centric-Parts-.../dp/B001O97L2Q The rear brakes are a smaller fraction of stopping performance, however, I found that the Centric Premium rotors offered performance that was at least as good as OEM and I found the price suitable. Pads: Hawk HPS http://www.amazon.com/Hawk-Performan...1&s=automotive These pads dust FAR FAR less than the OEM ones I had, are more silent than the lambs, and offer the same braking performance as OEM at a good price. All in all, pedal feel improved and braking performance improved after the change, no regrets. This is the preferred setup I would continue running. |
03-21-2013, 12:09 PM | #20 |
964
Rep 3,854
Drives: 330i, 135i
My rear set up total was $146.00 this includes rotors, pads, and sensor. No labor cost since I did it myself. No dust and performace is good.
03-21-2013, 12:13 PM | #21 | |
153
Rep 770
03-21-2013, 12:13 PM | #22 | |
153
Rep 770
