Necessary to turn the rotors before installing new pads?
03-20-2013, 04:46 PM | #1 |
1227
Rep 1,126
Topic says it all... Is it necessary to turn the rotors before installing new pads? I have OEM pads now and will be replacing them soon (and hopefully eliminating the dust!) and I will be using my OEM rotors. The rotors are in really good shape (I mean REALLY good shape - less than 60k miles). I would really like to avoid pulling them off if I don't have to.
Suggestions? |
03-20-2013, 06:58 PM | #2 | |
310
Rep 4,002
Good idea to file a small chamfer across the top and bottom of the brake pad to clear any lip prior to installation and the pad will bed in much faster. We recommend Cool Carbon Street Performance pads as better in all categories and without the on/off characteristic of OE pads with initial grabby feeling. Very linear and easy to modulate- Our favorite pad!!
Robert T. | european auto source (eas)
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
03-21-2013, 08:26 AM | #3 |
814
Rep 3,953
Go with Hawk pads. They are a better quality pad. With 60k if the rotors are original they may need to be replaced. If there is a big lip they are done.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
03-22-2013, 11:35 AM | #5 |
Rep 177
On most European cars, and new domestics, the rotors are made of a softer material that is designed to wear with the pads giving better braking and less brake fade over the entire life of the pad. Unless you have some very special eyes, there is no way to visually inspect the surface of a rotor unless it is badly warped. If you check the thickness with a micrometer and AFTER machining to a smooth surface it is still above the minimum recommended thickness (stamped on the lip of the rotor) then you do not have to replace them.
10/10 you should replace your rotors with pads on your first brake service. If you do not resurface your rotors, the uneven surface of your rotor will cause your pads to wear faster and may reduce the effectiveness of your brake system. |
03-22-2013, 11:49 AM | #6 |
Rep 55
Pretty much everyone now says replace both. I don't know that you have to, but, unless you track the car a lot you probably aren't replacing pads a lot. Might as well replace both.
03-22-2013, 12:40 PM | #7 |
1227
Rep 1,126
Thanks for all the replies! I bought the car last summer with around 40k on it, and I think it had had some previous brake work; however, I don't know when and how much was done.
I checked the rotors last night, and to my surprise there is a fairly large lip on the edges. I have to go into the dealer today to ask them about something else, so I am going to get their opinion on the rotors. Thanks all! |
03-22-2013, 01:02 PM | #8 |
964
Rep 3,854
Drives: 330i, 135i
Replace both if you can afford it. In terms of labor, its so easy to remove them. They only have one screw each.
03-22-2013, 09:47 PM | #9 |
1227
Rep 1,126
I was at the dealer today and talked with the tech, and he definitely suggested new rotors, so that's what I'm going with.
I'm thinking about getting these. Any thoughts? I don't think I need the R1 Concepts premium series, so I thought I would go with the Eline series. I am considering Cool Carbon or Akebono for brake pads, but I'm undecided as to which one to use. Any thoughts there? |
03-22-2013, 10:30 PM | #10 | |
147
Rep 1,319
2016 F80 M3 BSM with Black interior DCT/Driver Assistance/Executive/LEDs/Adaptive/Black Wheels
2014 F32 435i xDrive AW/CR 2014 F25 X3 M-Sport Carbon Black 2011 e92 335is 2007 X3 122k miles 2006 e90 330i 132k miles |
03-23-2013, 07:10 AM | #11 | |
1227
Rep 1,126
