Who can design/machine caliper brackets?
03-20-2013, 01:41 AM | #1 |
278
Rep 5,062
Drives: Black e92 335i
If you think you know how to do this or somebody who might please let me know or if you just want in on the project for a custom brake kit let me know, having some help would be great.
I've done a lot of the leg work to find some appropriate setups, now it's just about making them fit.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
04-02-2013, 12:49 AM | #3 |
12
Rep 162
Caliper brackets aren't as simple as a bracket that you're probably thinking of.
I thought I would need a new one when the moron that did the brakes for the previous owner used no anti seize and I stripped out all the threads in my bracket for the caliper carrier bolts. Anyways it's a complex shape and bmw casts them. I guess you could mill out a block to make them though.
| H&R Coilovers |ApexArc-8s| M3 ControlArms | RogueTransMounts | AFEDualCone | ERChargePipe | TialBOV | ETSIntercooler | 335isClutch | BMSCatchCan | UUC EVO3 SSK | MichelinPSS | CobbAP | JB4 |
04-02-2013, 11:31 AM | #4 |
9
Rep 302
There is this stuff called quick steel you can get. Definitely use that brand.
Pack the holes with it and screw the bolt into it lightly After roughly 3 to 4 min. Carefully screw the bolt out. The threads will harden as hard as the steel. Not always the best fix but it should work. Just to hold ya until you figure out what you are gonna do. Just an idea. And ya. If its more of a cast then i prob wouldnt be able to do it. Lemme know if ya got any other ideas |
04-02-2013, 11:57 AM | #6 |
12
Rep 162
Yeah that problem was resolved a year or so ago. I just drilled and tapped the bracket for a larger diameter bolt and then machined a new bolt that functions identically to the old one but has the same larger thread size.
05-07-2013, 02:31 AM | #8 | ||
278
Rep 5,062
There's a whole bunch of options that fit decently with the OEM brake bias, all that's really left to do is machine up a bracket for any of them. Quote:
Yupp
05-07-2013, 02:30 PM | #9 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
I'll just say that the calipers from Porsche Cayenne S will be a good match
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
05-08-2013, 10:09 PM | #10 |
278
Rep 5,062
Yup
05-08-2013, 10:15 PM | #11 | |
170
Rep 1,843
05-09-2013, 08:57 AM | #12 |
Hellafunctional
37
Rep 426
Have you called VAC? Maybe ECS? JHM?
Also, not to put the cart before the horse, but please make sure there are a plethora of street and track pad options out there for the caliper you choose. Plus, being able to fit under 18" wheels would be total win. I like the Brembo 17z calipers from the Touareg V6. 4 Piston, so you don't have to mess around with master cylinder issues. Piston sizes are 36/40mm. Plus, they are ~$300/pair!
Go: Cobb S2+, Big Tom FMIC, CP-E DP & DCI, Royal Muffler, AR OC Turn: TC Kline/Swift SA, Vorshlag Plates, UUC Front Bar, H&R M3 Rear Bar, VAC endlinks & spacers, Forgeline 18x9.5/NT05 265 Square Stop: Endless MX72, Stoptech Rotors/Lines, Motul RBF600 |
05-09-2013, 03:46 PM | #13 | |
278
Rep 5,062
The 18z is cheap and fits, but it requires some machining of the caliper. GT3 calipers work and fit very nice, but the cost is prohibitive.
05-09-2013, 05:48 PM | #14 |
Hellafunctional
37
Rep 426
Re: 18z - Hard to say no to painted, loaded, reman caliper pairs for $500 lol
Have you tried the actual brembo 355mm brackets for their 335i kit? I gotta believe economies of scale still apply to brakes, and there are so many Brembo mounting options... By machining do you mean to mount it, or to give clearance? Also, have you looked into the Centric semi-loaded reman gt3 calipers? Sorry for all the questions. Now that I've got my suspension and tires set up, brakes are next on the list. Running Endless street/track pads is getting expensive. I'd love to be able to swap pads quickly without having to pull the whole caliper!
Go: Cobb S2+, Big Tom FMIC, CP-E DP & DCI, Royal Muffler, AR OC Turn: TC Kline/Swift SA, Vorshlag Plates, UUC Front Bar, H&R M3 Rear Bar, VAC endlinks & spacers, Forgeline 18x9.5/NT05 265 Square Stop: Endless MX72, Stoptech Rotors/Lines, Motul RBF600 Last edited by Doyle; 05-09-2013 at 06:05 PM.. |
