Sport suspension? Coil overs?
03-14-2013, 03:51 PM | #1 |
9
Rep 302
If I already have the sport suspension and all I want to do is slightly lower my car (335i), what is my best option?
Im not trying to go cheapo on this im just not gonna be bringing my car to the track or anything like that so I didnt know how hi tech/in depth I needed to get. |
03-15-2013, 09:04 AM | #4 |
13
Rep 163
If you just want to go a little lower than stock, I would suggest getting Koni yellows w/ H&R Sport spring set-up.
If you plan on a coil over, ST is a great option (essentially the same as KW V1’s w/o the stainless body). This is my favourite choice and what I decided to do. If you go with the ST’s just remember to coat them before the winter with some rust check and once more half way through. Hope this helps. I would suggest buying the springs from ECStuning.com and the ST’s from fifteen52. |
03-16-2013, 01:07 PM | #5 |
14
Rep 455
bigger rims will fill wheel gap
or get supreme power lowering perch. with that your front ride height will be closer to having eibach springs installed. labor + parts for sp perches should be around 200-250 once you understand more about suspension and your intended use, buy something then.
JB4 G5 / VRSF IC / STETT CAI / GREDDY / custom exhaust / iRotora cross drilled rotots / snow stage 3 meth / 19" iForged senekas / upgraded speakers n CF woofer box / M3 bits/ DINAN camber plates/ KONI/ megan racing toe arm/ supreme power lowering perch
03-17-2013, 08:23 AM | #9 |
I got lei'd
844
Rep 7,593
I have ST coils, great set up after 11k miles in a year, if I could do it over again I would go bc coils, it gives you the option of choosing your spring rates and comes with front end links I believe, ST has no extras and its about the same price.
