Quafie Whine Question
03-09-2013, 09:40 PM | #1 |
52
Rep 748
After installing my VAC built Quafie last weekend, I have a slight high pitched whine when under light decel (engine braking in 6th at 70mph) or slight accel (cruise control on the interstate). It is not very loud, you can't hear unless the radio is off. The noise reminds me of the whine you hear when driving in reverse on most gear boxes.
Any ideas on what might cause this? Diff needing to be broken in? Improper build? Defiv lockdown NVH? I also have stock subframe bushings.
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
03-09-2013, 10:21 PM | #4 |
52
Rep 748
Thanks for the replies. That's what I was hoping, but didn't see anything with a search.
03-10-2013, 06:18 AM | #5 |
161
Rep 7,377
the diff should not be making any noise at all. mine is totally silent.
03-10-2013, 05:33 PM | #6 |
52
Rep 748
Well mine is silent 99% of the time. It is just on the interstate when coasting or slight accel. Seems like I am not alone, so as long as it is not a problem I don't mind the noise (which you can't even hear unless the radio is off.)
03-11-2013, 11:51 AM | #7 | |
30
Rep 216
I'm not sure what it is. I also have the defiv lockdown kit installed. |
03-18-2013, 06:22 AM | #8 |
1254
Rep 4,088
Anything that hard-couples a diff to the chassis or subframe can enhance gear noise and cause whine. If you were running totally stock bushings with no lockdown and had whine i would be worried about backlash, but in your case I suspect all is fine.
03-18-2013, 10:40 AM | #9 |
25
Rep 152
Same here, VAC Quaife LSD, Defiv Lock kit, M3 subframe bushings and whining... Also when Im in high gear cruising and start to accelerate in same gear sometimes there is really loud noise coming from the differential, anyone else with same experience, is this normal?
03-18-2013, 11:50 AM | #10 |
38
Rep 864
Drives: '08 E92 335i
I have a VAC-built OS Giken, with powerflex diff and subframe bushings. No noticeable gear whine.
03-18-2013, 11:52 AM | #11 |
125
Rep 3,004
I also have the Difflockdown with Wavetrac, zero Whine at any speeds. Just some clunking when first engaging into Reverse.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
03-18-2013, 12:50 PM | #12 |
1254
Rep 4,088
It's the diff lockdown. Hard mount means no damping of the natural whine that's already there.
Stock, M3, or poly bushings will all have decreasing levels of isolation inherent to the design. That all goes out the window with a lockdown hard mount, or if you go with Delrin or otherwise solid diff mounts. Subframe bushings have much less to do with this than diff bushings, unless again you are going full race delrin or Al bushings. Then you will have a lot more than just gear whine to add to your NVH! |
03-18-2013, 12:52 PM | #13 |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Gear whine is NOT normal and I suspect it has to do with install, backlash tolerances. My first Quaife had whine and I had it rebuilt, no more whine afterwards.
03-18-2013, 12:58 PM | #14 |
1254
Rep 4,088
Best thing to do is talk to VAC. They really do know their stuff especially when it comes to diff builds. I'd be really surprised if it is legit improper backlash given their expertise, but I will concede that it is possible.
03-18-2013, 02:34 PM | #15 |
164
Rep 2,556
My Quaife did the exact same thing for the first thousand miles, changed the fluid and it went away. Stock diff and subframe bushings at the time.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
03-18-2013, 03:27 PM | #16 | ||
52
Rep 748
Interesting, did you use the same fluid?
03-18-2013, 06:51 PM | #17 |
125
Rep 8,745
tcw, I experience same as you with Wavetrac, faint whine when letting off throttle!
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
03-18-2013, 07:26 PM | #18 |
52
Rep 748
Yea I think it is fine now, seems pretty common.
03-18-2013, 11:13 PM | #19 | |
164
Rep 2,556
03-21-2013, 09:28 PM | #20 |
194
Rep 933
These 'diff lockdown' kits logically introduce some sort of noise into your cabin. Same with solid bushings. Even poly bushings may add some extra N, V or H.
A diff should not whine, period. How people define 'whine' is very broad though. All cars IMO have some sort of driveline noise, esp if you are looking for it. Improper diff assembly whine is generally very evident and easy to ID. Over the last few years, we have had a few people stop in since they were were concerned with whine. I took them for a ride in our stock E90 M3 or our not so stock E92 and the same 'whine' was evident - but it wasn't really a whine at all. We put Redline 75W90NS in all Quaife diffs. Only OSG oil in the OSG diffs.
Brian Casella
Sales Representative, VAC Motorsports Office: 215.462.4666 | Fax: 215.462.4667 EXT 13 | Email: brian@vacmotorsports.com |
03-21-2013, 09:54 PM | #21 | |
Black on Black on Black.
38
Rep 532
LEMANS BLUE M-TECH E92->PROCEDE REV3::BIEHNTUNE FLASH::ETS 7" FMIC::RACELAND DPS::OS GIKEN 1.5 WAY::DEFIV DIFF LOCKDOWN::DEFIV OCC::DEFIV INTAKE::RB PCV |
03-22-2013, 04:24 PM | #22 | |
52
Rep 748
Yea I used Redline 75W90NS when I installed mine. Mike have you all by chance received my core differential back? I mailed it out Monday. Thomas
