rear ended 15000$ damage
03-08-2013, 01:19 PM | #1 |
15
Rep 220
insurance already paid me $2200 for initial estimate. after removing bumper estimate adds an ADDITIONAL $13,068.63. insurance is on the way to discuss with body shop. normal cost for certified bmw bodyshop? wonder if I can take the money and.... estimate breakdown for anyone interested Preliminary Estimate Job Number: Vehicle: 2008 BMW 335I 2D CPE 63.0LT Line Oper Description Part Number Qty Extended Price $ Labor Paint 1 # SUPPLEMENT #1 1 2 REAR BUMPER 3 R&I RT Vent grille 4 R&I LT Vent grille 5 # Refn TOW EYE CAP, DED W/O CLEAR 0.2 6 O/H bumper assy 2.2 7 * Repl Tow eye cap w/o aero pkg., ADD W/CLEAR COAT 51127161497 1 12.54 Incl. 0.2 8 # CLEAR COAT, ADD 1 0.1 9 Repl Center support coupe 51127128247 1 19.05 Incl. 10 R&I RT Outer support Incl. 11 Repl LT Outer support 51127128245 1 23.10 Incl. 12 # Repl LOWER SUPPORT 1 17.29 Incl. 13 Repl Energy absorber coupe 51127179678 1 227.27 Incl. 14 * Repl RT Energy absorber gasket 51127131741 1 2.26 Incl. 15 * Repl LT Energy absorber gasket 51127131741 1 2.26 Incl. 16 # Repl MOUNTING KIT, RR BUMPER 1 15.10 17 # Rpr PREP RAW COVER, DED 0.8 18 # Rpr REMOVE RELEASE AGENT FROM CVR, ADD 0.5 19 # Repl PLASTIC ADHESION PROMOTER, ADD 1 17.95 0.3 20 REAR LAMPS 21 * R&I LT Tail lamp coupe, ADD 4TH LAMP Incl. 22 * R&I RT License lamp coupe Incl. 23 * R&I LT License lamp coupe Incl. 24 R&I High mount lamp 0.3 25 TRUNK LID 26 # Rpr TRUNK LID, DED 1.0 2.3 27 # NO BASE COAT REDUCTION, DELEATE . 5P 1 0.5 28 * Repl Trunk lid, ADD 41617168515 1 651.09 3.2 2.3 29 Add for Clear Coat 0.9 30 Add for Underside(Complete) 1.2 31 # R&I WEATHERSTRIP, DED 0.4 32 * Repl Weatherstrip, ADD 51767166660 1 72.75 Incl. 33 * Algn RT Hinge 1.0 34 * Algn LT Hinge 1.0 35 R&I RT Lift cylinder 0.2 36 R&I LT Lift cylinder 0.2 37 R&I Lock cylinder w/code Incl. 38 # R&I RELEASE ACTUATOR Incl. 3/8/2013 9:35:41 AM 074180 Page 2 Preliminary Estimate Job Number: Vehicle: 2008 BMW 335I 2D CPE 63.0LT 39 R&I License bracket Incl. 40 # Repl NAMEPLATE, DELEATE 1 24.87 0.2 41 # Repl EMBLEM, DED 1 27.82 0.2 42 * R&I Emblem, ADD 0.2 43 Repl Emblem grommet 51141807495 2 0.78 44 # R&I TRUNK WIRE HARNESS 0.5 M 45 REAR BODY & FLOOR 46 * Rpr Rear body panel 9.0 1.8 47 Overlap Major Adj. Panel 0.4 48 Add for Clear Coat 0.3 49 * Rpr LT Floor extn 4.0 1.2 50 # CLEAR COAT 1 0.5 51 # Rpr REMOVE UNDERCOAT/CAULK 1.0 52 # Rpr WAX & GREASE REMOVAL 0.5 53 # Repl CAULKING 1 10.00 0.5 54 # Repl CORROSION PROTECTION, DED 1 10.00 0.2 55 # Repl CORROSION PROTECTION, ADD 1 5.00 0.5 56 # Repl COSMALINE COATING 1 8.00 0.5 57 # Rpr SETUP & MEASURE CHIEF 3.0 S 58 # Rpr PULL & SQ REAR STRUCTURE 3.0 S 59 # Rpr FABRICATE PULL TABS 1.0 60 # Rpr COVER FOR WELDING SPLATTER 0.5 61 R&I Rear body trim 0.3 62 R&I RT Side trim panel w/navigation 0.4 63 R&I LT Side trim panel w/navigation 0.4 64 R&I Battery cover 0.1 65 R&I Floor cover w/storage pkg 0.1 66 # R&I UNDERCOVER, FRONT 0.4 67 # R&I UNDERCOVER, TRANS 0.4 68 # R&I UNDERCOVER EXT, TRANS 0.2 69 # R&I UNDERCOVER, RT FLOOR 0.6 70 # R&I UNDERCOVER, LT FLOOR 0.6 71 # R&I UNDERCOVER EXT, RT FLOOR 0.2 72 # R&I UNDERCOVER EXT, LT FLOOR 0.2 73 # R&I RT JACK PAD (2) 0.2 74 # R&I LT JACK PAD (2) 0.2 75 FENDER 76 * R&I RT Rear LINER extn w/o M3 0.1 77 * R&I LT Rear LINER extn w/o M3 0.1 78 WHEELS 79 R&I RT/Rear R&I wheel m 0.1 M 80 R&I LT/Rear R&I wheel m 0.1 M 81 REAR SUSPENSION 82 * R&I Tension rod 0.6 M 83 Repl Align four wheels 1 m 2.0 M 3/8/2013 9:35:41 AM 074180 Page 3 Preliminary Estimate Job Number: Vehicle: 2008 BMW 335I 2D CPE 63.0LT 84 EMISSION SYSTEM 85 R&I Vapor canister m 0.5 M 86 EXHAUST SYSTEM 87 Repl Exhaust manifold gasket 18307553603 2 39.28 88 Rpl exhaust system m 2.0 89 Repl RT Converter & pipe remanufactured 18307592437 1 1,375.51 m Incl. 90 Repl LT Converter & pipe remanufactured 18307592448 1 1,375.51 m Incl. 91 Repl RT Converter & pipe clamp 18307560779 1 36.89 Incl. 92 Repl LT Converter & pipe clamp 18307560779 1 36.89 Incl. 93 Repl Center muffler 18307565541 1 582.38 m Incl. 94 Repl Center muffler clamp 18307560779 1 36.89 Incl. 95 # Repl RT REAR MUFFLER, DED 1 417.07 0.8 M 96 * Repl RT Rear muffler, ADD 18307563229 1 417.07 m Incl. 97 Repl LT Rear muffler 18307563228 1 535.78 m Incl. 98 Repl Rear muffler clamp 18307560778 1 36.89 Incl. 99 R&I Changeover valve Incl. 100 # Rpr ADJUST & WELD EXHAUST SYSTEM 2.0 101 # R&I HEAT SHIELD, RT FRNT 0.4 102 # R&I HEAT SHIELD, MID CENTER 0.4 103 # Repl HEAT SHIELD, RT REAR 1 56.76 0.4 104 # R&I HEAT SHIELD, LT REAR 0.4 105 BACK GLASS 106 R&I Back glass BMW 3.0 107 Repl Reveal molding 51317119713 1 32.92 Incl. 108 # Repl GLASS INSTALL KIT, BACK 1 81.06 109 # Rpr CLEAN URETHANE FROM GLASS 0.5 110 # Rpr ADD TO ATTEMPT TO SAVE GLASS 0.5 111 QUARTER PANEL 112 Blnd RT Quarter panel w/o M3 1.6 113 * Rpr LT Quarter panel w/o M3 1.0 3.2 114 Overlap Major Adj. Panel 0.4 115 Add for Clear Coat 0.6 116 R&I Fuel pocket 0.5 117 R&I Fuel door 0.3 118 Blnd Fuel door 0.2 119 R&I RT Pillar molding 0.2 120 R&I LT Pillar molding 0.2 121 R&I RT Belt molding w/high gloss 0.3 122 R&I LT Belt molding w/high gloss 0.3 123 R&I RT Splash shield w/o M3 0.4 124 R&I LT Splash shield w/o M3 0.4 125 R&I RT Quarter glass BMW 1.5 3/8/2013 9:35:41 AM 074180 Page 4 Preliminary Estimate Job Number: Vehicle: 2008 BMW 335I 2D CPE 63.0LT 126 R&I LT Quarter glass BMW 1.5 127 R&I RT Upper qtr trim gray Incl. 128 R&I LT Upper qtr trim gray Incl. 129 R&I RT Lower qtr trim w/leather black Incl. 130 R&I LT Lower qtr trim w/leather black Incl. 131 FUEL SYSTEM 132 * R&I Filler pipe, PARTIAL m 0.4 M 133 SEATS & TRACKS 134 R&I RT R&I rear seat 1.1 135 * R&I LT R&I rear seat Incl. 136 PILLARS, ROCKER & FLOOR 137 Blnd RT Roof rail s 0.9 138 Blnd LT Roof rail s 0.9 139 R&I RT Rocker molding w/o M3 w/o aero pkg. 0.8 140 R&I LT Rocker molding w/o M3 w/o aero pkg. 0.8 141 R&I RT Drip molding w/high gloss 1.1 142 R&I LT Drip molding w/high gloss 1.1 143 R&I RT Center plr trim gray 0.3 144 R&I LT Center plr trim gray 0.3 145 R&I RT W'strip on body 0.5 146 R&I LT W'strip on body 0.5 147 R&I RT Inner trim black 0.1 148 R&I LT Inner trim black 0.1 149 R&I RT Sill plate w/o aero pkg. Incl. 150 R&I LT Sill plate w/o aero pkg. Incl. 151 ROOF 152 R&I RT Roof molding 0.5 153 R&I LT Roof molding 0.5 154 RESTRAINT SYSTEMS 155 * R&I RT Seat belt assy black, PARTIAL 0.4 156 Repl LT Seat belt assy black 72119114283 1 169.56 0.9 157 Repl System diagnosis 1 m 0.5 M 158 ELECTRICAL 159 * Rpr Battery D&R 0.3 160 # Rpr DOWNLOAD & STORE CODES 1.0 M 161 # Rpr RESET ELECTRICAL CONNECT 0.5 M 162 # R&I WIRE HARNESS, REAR BODY SETBACK 1.0 M 163 INSTRUMENT PANEL 164 R&I RT Qtr pnl speaker w/o Harman Kardon 0.2 165 R&I LT Qtr pnl speaker w/o Harman Kardon 0.2 166 R&I RT Tweeter quarter panel w/o 0.2 3/8/2013 9:35:41 AM 074180 Page 5 Preliminary Estimate Job Number: Vehicle: 2008 BMW 335I 2D CPE 63.0LT Harman Kardon 167 R&I LT Tweeter quarter panel w/o Harman Kardon 0.2 168 WINDSHIELD 169 R&I Windshield BMW w/o climate comfort 3.0 170 Repl Reveal molding 51317119711 1 34.70 Incl. 171 # Repl GLASS INSTALL. KIT, W/S 1 81.06 172 # Rpr CLEAN URETHANE FROM GLASS 0.5 173 # Rpr ADD TO ATTEMPT TO SAVE GLASS 0.5 174 R&I RT Wiper arm Incl. 175 R&I LT Wiper arm Incl. 176 R&I RT Washer nozzle 0.2 177 R&I LT Washer nozzle 0.2 178 COWL 179 R&I Cowl grille 1.4 180 R&I Filter housing upper w/o M3 Incl. 181 R&I Filter housing lower w/o M3 Incl. 182 R&I RT Side cover w/o M3 Incl. 183 R&I LT Side cover w/o M3 Incl. 184 HOOD 185 R&I RT Side seal rear 0.1 186 R&I LT Side seal rear 0.1 187 R&I RT Upper seal 0.1 188 R&I LT Upper seal 0.1 189 R&I Rear seal 0.1 190 # Refn COLOR TINT 0.5 191 # Refn TINT PRIMER 0.5 192 # COVER CAR, DED 1 10.00 193 # Repl COVER CAR EXTERIOR, ADD 1 10.00 0.5 194 # Repl 2ND COVER CAR EXTERIOR 1 10.00 0.5 195 # Repl COVER UNDERCARRAGE 1 10.00 0.5 196 # Repl COVER INTERIOR 1 10.00 0.5 197 # Refn MASK FOR PRIMER 0.5 198 # Refn BACK MASK JAMBS 0.5 199 # Rpr DE NIB & POLISH, DED 0.5 200 # Refn COLOR SAND & BUFF 15.6 @ 30%, ADD 4.7 201 # Rpr FEATHER EDGE & BLOCK 1.0 202 # Repl CLEAN COLOR SAND RESIDUE 1 0.4 203 # Subl WASH FOR DELIVERY 1 12.00 X 204 # Subl BODY/PAINT LABOR 11.7 @ $3.00, ADD 1 35.10 X SUBTOTALS 5,610.93 76.2 19.8 3/8/2013 9:35:41 AM 074180 Page 6 Preliminary Estimate Job Number: Vehicle: 2008 BMW 335I 2D CPE 63.0LT ESTIMATE TOTALS Category Basis Rate Cost $ Parts 5,563.83 Body Labor 63.8 hrs @ $ 55.00 /hr 3,509.00 Paint Labor 19.8 hrs @ $ 55.00 /hr 1,089.00 Mechanical Labor 6.4 hrs @ $ 180.00 /hr 1,152.00 Structural Labor 6.0 hrs @ $ 75.00 /hr 450.00 Paint Supplies 19.8 hrs @ $ 38.00 /hr 752.40 Miscellaneous 47.10 Subtotal 12,563.33 Sales Tax $ 6,316.23 @ 8.0000 % 505.30 Grand Total 13,068.63 Deductible 0.00 CUSTOMER PAY 0.00 INSURANCE PAY 13,068.63 |
03-08-2013, 01:23 PM | #2 |
65
Rep 1,450
Wow, it doesn't look that serious from the outside but I guess the inside structure of the chassis absorbed all the impact.
03-08-2013, 01:24 PM | #3 |
Audaces fortuna juvat
9
Rep 543
wow... insurance rip off.. no way is that $15k damage!
..and you wonder why insurance rates are so high.. Last edited by Thrakos; 03-08-2013 at 02:06 PM.. |
03-08-2013, 01:34 PM | #4 |
8
Rep 476
More than one would expect from just looking at the picture. Let me know what happens, as I am in need of a passenger side front fender. Good luck, but that really doesn't look like anywhere near 15k in damage. Some of those recommendations are questionable. For example, is there a reason the trunk needs to be replaced? Looks fine from my perspective.
03-08-2013, 01:39 PM | #5 |
59
Rep 733
That looks like a couple grand in damage, why on earth are they replacing speakers though? And is the windshield broken too?!
2011 BMW 335i E92 Vermillion Red, 6MT [SOLD]
2008 BMW M3 E92 Alpine White, 6MT |
03-08-2013, 01:42 PM | #6 |
67
Rep 606
Drives: 2008 E92 328i
My car was hit in the rear as well, damage was worse than this and I paid $250 to fix.
{2008 e92 328i MT} 19" 313 wheels wrapped in Yokohama S Drive | FK Silverline Coilovers | Burgertuning spacers | Active Autowerkes Exhaust | Aero Front Kit | ZHP Shift Knob | City Vision AE | Coded Corners | |
03-08-2013, 02:08 PM | #8 |
37
Rep 384
When I rear ended a cab, my damage estimated was at nearly $10k, but it would have cost $3500 if done at an independent shop with used parts. Needless, I took the money, and sold the car as is.
SF90, G63, V12 Vantage, E46 M3. DD: M4
Gone: AventadorS, Urus, 13' Ferrari 458, AM V12 Vantage 6spd, M8, F82 M4, 2013 LP550-2, F430 Spider, AM V8 Vantage 6psd, E92 335i 6spd, 2003.5 E46 M3 6spd, Audi A7, 2011 BMW 550i, |
03-08-2013, 02:26 PM | #10 |
456
Rep 6,478
I'm seeing things on that part list that have essentially nothing to do with what looks like a fender bender. Speakers? New seats and interior trim?
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
03-08-2013, 02:36 PM | #11 |
428
Rep 2,136
I know, it even mentions windshield wiper arms, windshield washer nozzles... What the hell are they going to do? Completely disassemble the car and put it back together?
03-08-2013, 02:37 PM | #12 |
ALL RIGHTY THEN
222
Rep 2,957
you need new front wipers?
BMW CCA Member 483866
03-08-2013, 02:49 PM | #14 |
15
Rep 220
i laughed this.
-many of the things you see in the estimate are for removal and only labor work. -trunk is very very very slightly bent. insurance just called, they don't agree but the guy did say his estimate will probably be around 7-11k i will probably take the money because the bmw shop will not repair unless done to their spec. if any vendors see this and want to make money... let me know your cost for a new exhaust system, mtek bumper, and cost to install if possible... |
03-08-2013, 02:53 PM | #15 | |
29
Rep 128
You parting out? do you have a LED interior lights or anything thats good for a e90?
03-08-2013, 02:59 PM | #16 | |
456
Rep 6,478
03-08-2013, 03:52 PM | #17 |
26
Rep 218
I might have missed it. Is the front license plate bracket also listed?
ZPP, ZSP, NAVI, STEP, PADDLES, CA, PDC, HEATED SEATS, debadged, painted reflectors, plate frames, & keyhole cover, GP Thunders 8500 angels & fogs, Euphoria 6K High Powered Interior LED's, pearlescent E-brake handle, and mud guards, Split Second Turbo Tuner. |
03-08-2013, 04:07 PM | #19 |
158
Rep 3,158
That is an amazing bill there.
My car just got out of the dealership for insurance repairs--1/2 the front suspension, one wheel, two tires, the steering rack, and subframe connector (all due to hitting a chunk of ice at speed that lifted the front end of the car off the ground and SLAMMED it back down)......total bill $8600. One HALF the bill here. EDIT: Forgot to mention 1 adaptive Xenon HID assembly as well. You know that isn't cheap.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
03-08-2013, 04:08 PM | #20 |
25
Rep 150
i got hit and it looked very similar to that, cost almost 8k, i was waiting at a light and got hit, his insurance paid so the price was a non issue lol, also got an mtech bumper and blacklines out of it
03-08-2013, 04:16 PM | #21 |
24
Rep 857
Drives: 2008 Montego Blue 335i
My question is how the insurance company isn't totaling the car when it's an 08. $15k has to be close to 75% value I would think.
