The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > cutting portion of inner fender liner out
      03-05-2013, 11:43 PM   #1
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I need anybodys experience with cutting a portion of the inner rear fender out, can't see how this would hurt anything but thought I would ask. I have 285/25/20 with a 10MM spacer in the rear and I am rubbing a bit on the inner fender liner and want to cut it out. My fenders are already rolled so just the lining is in question here. I only rub on large bumps.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      03-06-2013, 01:01 AM   #2
longliven54
longliven54's Avatar
14
Drives: 2007 335i e90 auto
i believe rear camber can be adjusted. wouldnt that help?
JB4 G5 / VRSF IC / STETT CAI / GREDDY / custom exhaust / iRotora cross drilled rotots / snow stage 3 meth / 19" iForged senekas / upgraded speakers n CF woofer box / M3 bits/ DINAN camber plates/ KONI/ megan racing toe arm/ supreme power lowering perch
      03-06-2013, 02:45 AM   #3
crypticc
United Kingdom
73
Drives: e92 M3 DCT + Comp
If u live in area with water salt and grit I wouldn't. Imagine the rust under your fenders once the wax oil has been washed away with no protection
      03-06-2013, 02:52 AM   #4
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I may just take the liner out and put 3M tape on other side. It is hitting right on the edge by the fender lip.
      03-06-2013, 02:53 AM   #5
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
It would a bit but I am hitting right on edge.
      03-06-2013, 03:31 AM   #6
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
Let the tire chew the liner over time.
      03-06-2013, 06:36 AM   #7
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
can't stand the noise lol!
      03-06-2013, 10:36 AM   #8
longliven54
14
do it in a way that once you change your wheel setup, you can put the liner back.
or maybe a 12mm spacer instead of 10.
      03-07-2013, 08:46 PM   #9
Hybrid For Life
Germany
79
Drives: Out of Spec
I pulled the fender liner out and used a dremel tool with a cutting wheel, this worked great for me when I have my volks.
      03-07-2013, 11:01 PM   #10
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Exactly what I did lol! Also did a lot off cutting on rubbing points in the back/ quarter panel meeting area and also in the front clip/ fender meeting area.
      03-31-2013, 01:13 PM   #11
d3l0n
I love the ///M3, but I want 550hp ///M5
d3l0n's Avatar
Drives: BMW330iE90
any cons to this?
      03-31-2013, 04:24 PM   #12
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Originally Posted by d3l0n View Post
any cons to this?
None so far!
