Ohlins
03-04-2013, 07:48 PM | #2 |
298
Rep 4,040
Drives: 130i coupé ;)
Apparently not too low. You have to use SWIFT springs to get lower on Ohlins R&T
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
03-05-2013, 12:00 AM | #3 | |
Evo Junkie
35
Rep 157
How low do you want to go? You can adjust so the front arch lower lip about level with the tyre top edge, and the rear tyre is fairly well up into the arch. |
03-05-2013, 02:18 AM | #4 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Too soft for what? The race track maybe, but for road use I find them just fine thank you.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
03-05-2013, 02:21 AM | #5 | |
8
Rep 155
Ive been researching coils and these are getting great reviews and i dont know what will be best for my setup? |
03-05-2013, 06:44 PM | #6 | |
Evo Junkie
35
Rep 157
Also, if you work out the suspension frequencies, the front/rear ratio is completely out of wack. Standard, it has a rear bias of 6.7%, the Ohlins standard rates create a forward bias of 34.6% and this ruins the balance of the car. If all you want is to bimble about, then it's fine (and you could have saved £1000 and fitted Koni's and Eibachs for an even comfier ride) If you want any sort of decent dynamics on the road, then the rear rates are far too soft. I run an E91 (my shopping/tow car) and have used Koni yellows/Eibachs, then Ohlins with the standard rates, 343/672 and 400/800. |
03-05-2013, 06:57 PM | #7 | |
Evo Junkie
35
Rep 157
The standard fronts with 672 rear swifts is a really nice setup. You'll preferably want uprated subframe bushes with these springs. The Ohlins dampers are very, very good. |
03-06-2013, 12:50 PM | #8 |
91
Rep 817
I noticed that the kit for the E92 M3 comes with the same front spring rates as the non M but much stiffer rear rates:
SPRING RATES: Front: 60 N/mm (343 lbs/in.) Rear: 120 N/mm (685 Lbs/in.) M as opposed to 60 N/mm front and 70 N/mm Rear for non M. I wonder what the reasoning behind this is, is the lower rate based on the softer subframe bushings for the non M or do you think it's just that the M3 rear set up is different? |
03-06-2013, 01:41 PM | #9 |
1559
Rep 4,109
Drives: BMW M3
My educated guess as to why the non-M has lesser rear spring rates vs the M3 is because the non-Ms don't come with LSDs from the factory.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
03-06-2013, 04:40 PM | #10 |
Evo Junkie
35
Rep 157
That, aswell as the M3 uses much stiffer subframe bushes allowing harder spring rates. Higher rate rear springs and soft subframe bushes will cause the subframe to be 'levered' away from the chassis, causing even more subframe movement and the unsettled feeling it gives.
03-06-2013, 05:10 PM | #11 | |
1559
Rep 4,109
Drives: BMW M3
03-06-2013, 09:49 PM | #12 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Ohlins are designed for ~20mm lowering. Some cars may see more lowering. Beyond that, you will need to replace the Ohlins springs with Swift of proper length and rate.
03-06-2013, 09:52 PM | #13 | |
3847
Rep 54,376
Drives: F80 M3
03-07-2013, 12:11 PM | #14 |
8
Rep 155
03-07-2013, 12:13 PM | #15 |
3847
Rep 54,376
Drives: F80 M3
