245/45/19 on Sport Suspension? Also - How much of a spacer needed to clear the hub?
03-01-2013, 09:47 PM | #1 |
169
Rep 345
Picked up some very special wheels tonight, and I'm wondering if I can make them work without having to dismount the tires. Also, the hub bore is only 65mm on the new wheels, so I have to get a spacer to clear the center hub on the car.
Question #1 - Can you drive on 245/45/19's on a stock E92 sport suspension? Question #2 - What size spacer do you need to clear the hub on E92's? My guess is only ~5mm, but it'd be nice to know 100% Normally I'd just figure this stuff out, but living in a condo is having its disadvantages right now . Thanks to anyone that can help! Can't wait to unveil the new wheels. Pretty much guaranteed no one has ever had them yet
‘22 X3 M40i LCI
03-02-2013, 12:54 AM | #2 |
163
Rep 2,823
Tyres are way too big. What are the wheel specs? Are they 5x120?
No way 5mm spacer is enough. Bmw hub collar is around 10-12mm long.Even 10mm spacer isn't probably enough, because there is no room to make the spacer collar narrower for the 65mm hub bore. You are probably looking something like 15-20mm.
03-02-2013, 01:00 AM | #3 | |
169
Rep 345
Yea, these are 5x120. 19x8 with a 40mm offset and 65mm hub bore. If the hub collars are that long, I guess I can still get away with a 10mm spacer though. I'm just really really really trying to avoid boring out the wheels as I don't trust any shop to do it correctly
‘22 X3 M40i LCI
03-02-2013, 01:53 AM | #4 | |
163
Rep 2,823
But your wheels are 19x8 et40 so i would go 15mm spacer to front and 25mm to rear, just because it will look better.Of course with correct tyre size 235/35/19.
03-02-2013, 02:11 AM | #5 |
OPN DIFF
475
Rep 1,908
Drives: 10' E90 M3 6MT LB
That's a super tall tire to fit even on stock suspension...
'10 LB E90 slicktop/speed cloth/6MT ex. '06 330i 6MT & '10 n54 6MT Msport Autocross vids https://www.youtube.com/user/tigermack https://www.instagram.com/tigermack |
