F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Code to turn off Reverse Light Error Check for LED use
Extreme Powerhouse
      03-01-2013, 05:17 PM   #1
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
Question Code to turn off Reverse Light Error Check for LED use
How do i code it so that my car doesn't check for error in the reverse lights? I put in error free LED reverse light but it flickers when i turn on car and randomly while driving.
Another member told me its the car constantly checking bulbs so it flicks when it check. Said it's possible to code it so it doesn't check.
Is there an option to just code the reverse check only or if code the check off then its for all lights in car?
      03-03-2013, 01:07 PM   #2
UhhItsANT
bump
      03-07-2013, 12:04 AM   #3
zeezz
10
Drives: F30 328i Sport Line
Me and awhk were playing around with this in coding, try reading his post here:
http://www.f30post.com/forums/showth...0&post13208390
basically, there are a few settings for each bulb... cold check, warm check, and IS_LED. you want to set the checks off for whichever bulb you are changing to LED, and also set IS_LED to 'aktiv'... let me know if that works for you. BTW the chart says REF_01 module but mine was in the REM_01 module.
      03-07-2013, 06:01 PM   #4
UhhItsANT
thanks but yeah i found it someone gave it to me in the coding forum. it work worked for me. did exactly as you said. Code a total of 6 things to get it to work.
THanks.
      03-25-2013, 01:02 AM   #5
UhhItsANT
Originally Posted by rustyminded View Post
hey man I want to knw where you bought these, I already got the front signals but I need for back turn signals, reverse and brakes too ?
i bought some from **************** on this forum...
http://www.f30post.com/forums/member.php?u=65772
or you can go email also.
size is p21
      03-25-2013, 04:52 AM   #6
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
thank man so I order from them brake and turn signals too or they offer only reverse ?
      03-26-2013, 12:19 PM   #7
UhhItsANT
im not sure. you would have to ask them. They contacted me informing me they had reverse led when i was looking.
      03-31-2013, 10:57 PM   #8
UhhItsANT
could you please upload pics or tell me how to go through the tail light for turn and brake lights cuz when I try to reach from the trunk all I see is a piece of metal and I can't remove anything.. and did you buy the rear turn signals cuz he told me it needs a resistor did anyone tried that or even tell me how it's done cuz i'm not pro and i don't want messing with my car
i havent changed the turn signal or brake lights. so i dont know. look inside the manual it shows you how to change it.
      06-06-2013, 10:55 AM   #9
remotecontrol
Drives: F30 320D
Just a quick question. Can you explain what IS_LED does? It's Not-Active as default and you mention that it needs to be changed to Active. Is this function for LED light for future F30 LCI model?
      06-07-2013, 12:33 AM   #10
Chris@codemybimmer
BimmerPost Supporting Vendor
Chris@codemybimmer's Avatar
171
Drives: AW F30 328i Xdrive
it provides the led with less amps so it wont burn your bulbs/fuse or other electricals
if you are using cree leds though do not set is led to active as it wont provide enough power
thats from my experience
I could be wrong
      06-07-2013, 12:35 AM   #11
Chris@codemybimmer
171
if you open your trunk and look at the gap between the trunk and brake/signal lights there's a grey piece thats held on by one screw.
unscrew it and pull that piece out you will see 2 hex bolts that hold your tail lights onto the car.
unscrew those and gently pull the tailight out
unplug everything and your good to do w.e you want to do
      11-05-2013, 07:36 PM   #12
vip
vip's Avatar
Drives: 2001 Alpine White M5
looking at some old threads here, but looks like you know how to code...??
would love to have you code few things on my f30 if you're up for it..
sent from bimmerpost Android app
      11-05-2013, 07:37 PM   #13
vip
vip's Avatar
hey Ant, do you still do coding?
      11-23-2013, 10:24 AM   #14
UhhItsANT
I haven't done any in over 9 months. Haha.
f30post
