X3 to 335i ?
02-28-2013, 12:08 PM | #1 |
Rep 135
X3 to 335i ?
Found a set of wheels localy I like but the selling is stating they are 140 offset. They are off an X3. Is he wrong? Here is what is posted on the add. Will these fit my 07 E92?
1 set of Staggered rim for BMW and some ACURA and HONDA Beyern Silver Mesh mag wheel (3 inch lip on rear and 1.5 on front) Size: Front 18X8.5, Rear 18X9.5 Bolt Patern 5X120 Offset 140 Wheels only: $550, Wheels and Tires: $750 Were mounted on a BMW X3 Currently installed are General Exclaim UHP Ultra High Performance Summer tire Tire Size 235/50/R18 and 255/45/R18 Tire in very good condition. |
02-28-2013, 08:53 PM | #3 |
23
Rep 717
There is no way a wheel has 140 offset. Probably hit the "1" but accident so the real offset he is referring to is 40. If the offset is 40, then yes it will fit your e92.
Edit: I saw the ad you are referring to and the offset was updated to 40. |
03-01-2013, 06:17 AM | #4 | |
Rep 135
Has anyone heard of these wheels? Any experience good or bad? I should do a search first I guess. |
03-01-2013, 07:20 AM | #5 |
23
Rep 717
The wheels are okay aftermarket wheels. However you will need spacers on both the front and rear because the offset is pretty weak. Those offsets won't look nice on a e92. Factor in an extra $200 for spacers in your purchasing decision because you can easily run 12 mm spacers in the front and rear.
03-01-2013, 01:57 PM | #6 |
A family of bimmers
2747
Rep 7,742
tire sizes are also off for the e9x
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
03-02-2013, 05:29 AM | #7 |
Rep 135
I'm little confused now, factory off set with the sport wheel is 40 front and 35 rear. However I also have read on a sticky in this section that the wheel I have (same as in picture to left) are 8" front and 8.5" rear. Just took a tape to mine in garage and mesured 9 front and 9.5 rear. or are the wheels measured inside the bead? I also found these off a 1 seires.
Size: Fronts: 19x8.5 ET44 Rears: 19x9.5 ET27 Offset: 5x120 Will they look ok? |
03-02-2013, 12:39 PM | #8 | |
23
Rep 717
Spec are: Front: 18x8, et 34, Rear: 18x8.5, et 37 The wheels from the 1 series you are referring to is decent. For the front you can get 12mm or 15mm spacers for it (because you can easily run 19x8.5, ET 30 on the front). The rear are fine (19x9.5, ET 27 is ideal), so you don't need spacers. |
03-03-2013, 07:33 AM | #9 |
Rep 135
Found another set in Toronto that are currently on a 5 sieres. He is useing spacers (forget how think and on what wheels). He told me they came off a 3 seires. I have asked him for part numbers or acurate off set. But they are the wheel I want and looks like they have first class rubber on them.
What is your experience with off set difference from 5 to 3's? here is add http://ottawa.kijiji.ca/c-cars-vehic...AdIdZ453499239 |
03-03-2013, 10:26 AM | #10 | |
1569
Rep 29,202
03-03-2013, 12:50 PM | #11 | |
23
Rep 717
Keep in mind that the standard/recommended setup rear wheel/tire setup for non-M E92 coupes is 19x9.5, ET 35 with 265/30/19 tires. With this setup you can add 10mm spacers (anymore and you will rub) on stock sport suspension without fenders rolled. You can have your fenders rolled if you want it more aggressive. |
03-03-2013, 01:18 PM | #13 | |
Rep 135
I see alot of square setups. Would the car handle any different with non staggard? I know I could go with different rubber on a square setup too right? |
03-03-2013, 02:45 PM | #14 | |
23
Rep 717
Avoid mixing tire brands/types even if you are running a staggered setup. Use the same tires on all 4 wheels. |
03-03-2013, 05:12 PM | #15 | |
Rep 135
03-09-2013, 06:49 AM | #16 |
Rep 135
These are on an E90, I am pretty sure there won't be any fitment problem, but wanted to double check here. they are;
18 x 8.5 ET35 18 x 9.5 ET33 They'd be fine right? |
03-09-2013, 10:19 AM | #17 |
23
Rep 717
