9.5 et 30 in front help!!
02-27-2013, 01:33 PM | #2 |
BimmerPost Supporting Vendor
2042
Rep 25,989
What coilovers?
I'd recommend taking a look at your setup now and measuring how much clearance you have on the inside, between your wheels and your suspension.
VMR|Wheels | 714.442.7916 |
04-03-2013, 03:58 PM | #8 |
OPN DIFF
475
Rep 1,908
Drives: 10' E90 M3 6MT LB
Sweet! I just picked up some 18x9.5 all around. lol
'10 LB E90 slicktop/speed cloth/6MT ex. '06 330i 6MT & '10 n54 6MT Msport Autocross vids https://www.youtube.com/user/tigermack https://www.instagram.com/tigermack |
04-04-2013, 02:17 AM | #9 |
8
Rep 155
thats good to here, i ordered 19x9.5 +25 up front should have lots of room. In the rear ill be running 19x11 +30. Do you think the fronts will stick (poke) out more then the rear?
04-04-2013, 02:25 AM | #10 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
19x11 +30? I think you MIGHT hit the shock? I could be wrong though.
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
04-04-2013, 02:57 AM | #11 |
557
Rep 5,367
thats a pretty even poke setup if you keep the natural rear camber. The front will poke 6mm @ -.65 and the rear 8mm @ -1.8. If youre ok with that then its good, but i rather have matching camber all around for the aesthetic sakes. 11 +30 will still put you at 25mm away from the shock.
You can follow my builds on IG: Tee212 |
04-04-2013, 03:05 AM | #12 | |
8
Rep 155
Thanks for the quick response, sounds like you been threw this shit lots before lol!!! do you think id need camber plates up front or should i be good? was thinking of running ohlins or save some cash and get bc racing.Thanks for your help much appreciated. |
04-04-2013, 03:20 AM | #13 |
557
Rep 5,367
If you decide for plates you can run a 10-11 front. im currently on a 10.5 +15 @-3.6 with 15mm poke. Had i known what i did now 3 years ago i would of gone wider. I would rather you run a set of BC coil due to its fair pricing and flexibility as it comes with plates. Up to date no one complain about its quality or performance (in other car forums as well).
I would recommend you opt for stiffer spring rates all around as most coil setup are 210/550lbs which is fine for a flush setup but its not stiff enough to keep the the wheel from banging on your fenders with a poke setup. If you notice the few members with 9.5/11 +25 on here that their soft suspension is keeping them from going any lower due to fear of fender damage/rub. BC offers swift spring upgrades options. So the plates/stiffer springs will open up front width possibilities. so its up to you. I posted alot of specs and info on my setup in this thread, if you have time you can look thru it. It didnt happen over night for me, it took lots of trial error broken fenders but im very happy with the results. http://www.e90post.com/forums/showth...=723336&page=7
04-04-2013, 03:31 AM | #14 | |
8
Rep 155
04-04-2013, 03:56 AM | #16 |
557
Rep 5,367
ya thanks man, you can search around in here about BC coils and the owners would vouch for them. im not dissing the other "better" branded coils used but givin it price and what im expecting from it, then they no longer fit the bill for my setup. Im not going to spend 1300+ with soft rates without plates that which does support a poke setup.
