02-24-2013, 04:55 PM | #2 |
289
Rep 1,575
I would contact Terry Burger the owner of Burger Motor sports and ask him directly. I emailed him and he told me there were AH3 owners with the stage 1 tune out there...but I would reach out to hear it from him personally.
02-25-2013, 04:26 PM | #4 |
Internet Ninja
53
Rep 626
anyone reach out to him yet?
03-25-2013, 06:08 PM | #7 |
342
Rep 1,352
Drives: 2018 M3 CS
Does it affect the hybrid system and its integration at all?
2018 M3 CS F80 l SMB l EXEC
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG |
04-11-2013, 12:37 AM | #11 |
Internet Ninja
53
Rep 626
I have a JB4 sitting in my office. I am just afraid to install it. I'm hoping someone does it first..lol...
04-14-2013, 09:20 AM | #12 |
46
Rep 365
Yea it's a scary thought. What would this engine cost to replace? 20k.... IDK but I am in the same boat as you. My thought is its gonna confuse the Hybrid system and maybe blow something. I might check into to M performance kit and see what that does or even if its possible to instal.
04-14-2013, 12:19 PM | #13 | |
867
Rep 6,248
04-14-2013, 04:50 PM | #14 | ||
Professional
50
Rep 977
04-15-2013, 07:27 PM | #15 |
46
Rep 365
09-10-2014, 12:57 PM | #16 |
142
Rep 931
Installed ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
09-18-2014, 01:12 PM | #17 |
Maximum Effort
57
Rep 59
I've added the JB4Stage 2 tune to my AH3.
It works flawlessly, I'm using Map1 as I have no other modifications. I notice a difference in power over stock and this does not in any way interfere with the hybrid operations of the vehicle. Just make absolutely certain to disconnect the battery BEFORE attempting any kind of installation. You should be able to do the installation yourself. Some tips: 1) Print out the installation instructions in color for reference. 2) If stage 2, ignore the tapping location in the install guide for the two can wires and instead access them from the plastic shielding (this simply reduces visible detection of the pinhole splice) 3) Note for the stage 2 install, this requires power and you will need a T50 torx bit to loosen the power bolt, but if you don't have or want to buy this part, just get some thick, double-sided adhesive tape and wrap it around the bolt, and then use vice grip pliers to loosen. 4) remember to disconnect battery before any work! 5) You might get an error when reconnecting battery and turning vehicle on, - this is normal and a simple switch off, then on again of ignition clears it. 6) Find a plastic food bag, and wrap the JB4 prior to installation to protect from potential water exposure...I simply used tape to seal it around the wires. 7) I placed the JB4 underneath the rear plastic cover ( this can be easily lifted off by turning the plastic locking bolts a quarter turn) for increased protection. 8) Enjoy! Last edited by RLSinCO; 09-18-2014 at 01:31 PM.. |
Chicken_Joe606.00 ah3julien1.00 |
09-18-2014, 01:16 PM | #18 |
BimmerPost Supporting Vendor
24183
Rep 190,777
09-18-2014, 01:25 PM | #19 |
142
Rep 931
Ordered JB stage 1 for my AH3
Stay tuned for review, pics and performance analysis
09-18-2014, 01:27 PM | #20 |
Maximum Effort
57
Rep 59
By the way, I should add that I find it incredible that I can still average 42+mpg on my commute to/from work, but still have the ability to unleash a beast from within this car.
My car brethren are in awe of the combination of fuel efficiency and power. |
09-18-2014, 01:28 PM | #21 |
Maximum Effort
57
Rep 59
Arrgghhh, forgot to add in my tips section: find a plastic food bag and wrap the JB4 prior to installation...just tape around where the wires exit. This is to reduce likelihood of water damaging the unit.
I'll modify my post, above... |
09-18-2014, 01:35 PM | #22 |
Maximum Effort
57
Rep 59
If you are planning to capture performance analysis, did you also get the USB cable? You can easily run this from under your hood, through a crack in the passenger door (while still being able to close the door) in order to connect to a laptop. You will need to do so to capture data during WOT runs. In addition, this is the most simple way to determine which map is currently active...
