Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > BMW or Akebono brake pads?
      02-21-2013, 05:05 PM   #1
isd8266
isd8266's Avatar
Drives: 2009 335i Xdrive
Hey Guys,
I'm sure this question has been asked time and time again but I was looking for some newer insight on it. I have to replace both the front and rear brakes on my 09 335i xdrive this spring and am debating between getting the BMW pads front(34-11-6-794-917) and rear(34-35-6-789-445) or getting the Akebono fronts (EUR918) and rears(EUR1170). Has anyone used both and if so how would you compare the two of them?
      02-21-2013, 05:39 PM   #2
TheBingoBalls
TheBingoBalls's Avatar
3821
Drives: BMW
Just from reading other threads, you'll eliminate most if not all brake dust but the bite/braking isn't as good as the OEM pads (not saying they're terrible at braking but you'll have to apply more pressure to the pedal).
      02-24-2013, 03:29 PM   #3
J-Spec Dan
ALL RIGHTY THEN
J-Spec Dan's Avatar
Drives: 12 STX Advance
Originally Posted by isd8266 View Post
Hey Guys,
been running akebono pads for couple of years. instead of having to clean wheels twice a week with OEM pads, only have to clean them once a month or so. bite is definitely not as hood as oem. same goes with pedal feel. for everyday driving, akebono pads is the way to go.
BMW CCA Member 483866
      02-26-2013, 01:28 PM   #4
Hybrid For Life
Germany
78
Drives: Out of Spec
i have akebono in the rear and akebono fronts are on the way, brake dust is deffinetly noticeably way less. bight is slightly less compared to oem. for street use akebono is the way to go especially if you have high spoke count wheels like i do.
