F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > DIY M Performance Brake Install?
Extreme Powerhouse
      02-17-2013, 04:07 PM   #1
reidpath
Drives: 328i
How hard is it to upgrade from stock brakes to the colored M performance brakes? I have access to a garage on the base I am stationed at where I can do it. I'm trying to weigh having the dealer do it vs doing it myself. How many labor hours for the dealer to do it?
      02-18-2013, 09:20 PM   #2
JamesMA
JamesMA's Avatar
81
Drives: 2018 F80 ZCP
Do a search. The issue is not the labor, but the coding which needs to be done to the computer to properly accept the brakes.
Apparently the biggest issue with these cars is the fact you can't even change the battery yourself anymore without coding.
2023 G80 ///M3x Comp. BSM on Black M Brakes
Gone: 2018 F80 ///M3 ZCP 6 MT, 2013 F30 335i 6MT M-Sport
      02-19-2013, 06:12 AM   #3
ykau
7
Drives: F30 320I
exactly. even new steering wheel with OLED display also require coding.
For M-performance bbk , you confirmed need coding for the braking effectiveness. I just done mine.
      02-19-2013, 06:31 AM   #4
reidpath
Drives: 328i
I have the coding part down. It is pretty simple actually.
I'm more interested in the install...
      02-26-2013, 04:02 PM   #5
ronin951
ronin951's Avatar
44
Drives: 2013 328i M-Sport
I've done brakes and capilpers before. Pretty straight forward. Just R&R. The biggest pain is bleeding, which from what I've read power bleeding is a must for these. When I do mine, I'll old school bleed them and have the dealer power bleed when they re-code it.
That said, you will get messy. You might eat and/or inhale some brake dust and you will definitely hold your breath when pulling out of the driveway for the first time
Just a tip. Since you're in MD/DC, if you make your way over to the Dulles Greenway around 2am it's a great straight to bed the brakes and not have to worry about being hit from behind. Depending on your pad selection you may even get to see some sparks fly!
f30post
