Technical question about abs bleeding and closed systems
02-17-2013, 08:08 AM | #1 |
1254
Rep 4,088
I was thinking about this recently when I bled my abs module using the poor man's method (no INPA here). My question is, if you necessarily need a method to "open" the abs module in order to bleed out trapped air, why then would trapped air in the module even contribute to a soft pedal under normal use? Succinctly, if the fluid and any air in the module is hermetically isolated from the rest of the system until activated, shouldn't a system's pedal feel not be influenced at all by the module under normal braking?
02-17-2013, 01:27 PM | #2 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
02-17-2013, 02:19 PM | #3 |
1254
Rep 4,088
Slippery road, brake hard, engage abs. Return to base, bleed. Big bubbles come out about forty seconds into the bleed (freshly bleed before already).
Not a glamorous as using INPA, but it worked. |
