coming into a good amount of extra money
02-16-2013, 06:48 PM | #1 |
23
Rep 142
Drives: 2006 325I sport 6mt
so at the end of march early april i am coming into a good amount of money, about 3k. I am torn between suspension set ups. kw variant 3 or the bilstein pss9/10. I have been out of the tuning game for about 6 years now and was a japanese car guy before. so basically which do you think is better and do any of you have experience with either? thanks for your advice and input.
02-16-2013, 06:54 PM | #3 | |
54
Rep 2,907
02-16-2013, 07:00 PM | #4 |
23
Rep 142
Its a daily driver and I drive about 45 minutes to and from work. I enjoy a stiff aggressive ride for when I get onto some back roads and get on it but still want to be able to have drive-ability. It will be sitting on 19x9 as well but i still have not decided on a tire. I also want to be able to take it to track days. btw its a 06 sedan manual trans 325i sport package
02-16-2013, 07:00 PM | #5 |
23
Rep 142
02-16-2013, 07:19 PM | #6 | |
54
Rep 2,907
On top of that, I would look into adding some more negative camber in the front which can drastically improve the handling characteristics of our cars. This can be achieved through adjustable camber plates (~$500), fixed camber plates (~ $200 from Dinan), M3 LCAs (lower control arms - ~$300), or a combination of camber plates and LCAs. There are other M3 suspension bits that you can add, but I don't think they will provide as much feedback as the LCAs and should be added after the LCAa, or if you have they money, at the same time, but not before (jmo). Other than that, you can add the M3 rear subframe bushings, stiffer sway bars, etc... but at that point, you're walking a fine line of making the car too stiff and without an LSD ($$$$), that's not something that you want. Last edited by WesleyC; 02-16-2013 at 07:25 PM.. |
02-17-2013, 04:31 AM | #7 |
Rep 288
I would (and probably will) go with Koni FSD shocks, Eibach springs, adjustable camber plates, M3 front control arms (all of them) and rear links, and UUC sway bars. Koni/Eibach combo is quite compliant with poor road conditions, but will still perform well on a track.
Since your car is 6+ years old, the control arms will make even more difference than usual, due to the age of your current bushings. With the right tire choice, it will grip like velcro. Dont forget about the brakes! |
02-17-2013, 08:10 AM | #8 | |
146
Rep 1,160
Now yer talkin'. I have Yellows + linear Eibach's and can give 'em a thumbs up for daily driving. Much more comfortable than stock. I installed this package - well known for performance. HP Autowerks solution should work as well. Did a number of other easily available suspension mods - superb. Don't track - just wanted my ride t'perform. Yup! |
02-17-2013, 09:24 AM | #9 |
411
Rep 3,049
Drives: 2009 BMW 335d
02-17-2013, 10:41 AM | #11 | |
23
Rep 142
02-18-2013, 05:50 AM | #12 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
If you've got that kind of money to spend, it's Ohlins Road and Track. End of.
http://www.roadandtrackbyohlins.com/products/bms-mi00/
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
02-18-2013, 07:04 AM | #13 |
1559
Rep 4,109
Drives: BMW M3
TC Kline has solid options in your price range, the damping is very good. TCK uses Koni dampers but re-valves them. Here's the single adjustable kit:
http://store.vacmotorsports.com/tc-k...tem-p2349.aspx
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
02-18-2013, 07:31 AM | #14 | |
Jumping Jack Flash
321
Rep 1,692
Drives: 2021 X3 M40i
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
02-18-2013, 02:42 PM | #15 |
1559
Rep 4,109
Drives: BMW M3
02-18-2013, 10:32 PM | #16 |
23
Rep 142
So I am going with the bilstein. A few of you were talking about m3 control arms. Will they fit and where can I order them. where do you all order your parts from anyway? whats a good website?
02-19-2013, 02:35 AM | #17 |
Bausman
63
Rep 1,817
