Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > need tire size recommendation...going a little more agressive this time.
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      02-16-2013, 10:22 AM   #1
import36
Burrito bowl connoisseur
import36's Avatar
Drives: 2015 Nissan GTR Black Edition
hey guys...
i'm looking for the tire fitment gurus of the forum. i'm looking to run a little more agressive wheel fitment than my current TE37 setup. the specs on the wheels are as follows:
18x9.5 +35 Fronts
18x10.5 +22 Rears
this is going on a 08 335i E92....my rear fenders are rolled and i'm dropped on KW V2s....so i can make adjustments to ride height. i know i'll have to run a somewhat stretched tire....but i'm ok with that.
can i please get some tire size recommendations from the fitment gurus to avoid any potential rubbing. thanks in advance everyone!
      02-16-2013, 03:32 PM   #2
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
Here is a setup that has a little bit more aggressive specs.
http://www.e90post.com/forums/showthread.php?t=800425
These are probably the best bet on tire size
235/35/19 or 225/35/19 to front
265/30/19 or 255/30/19 to rear
You will need spacer to front. 19x9.5 et35 won't clear coilovers from inside.
      02-16-2013, 04:13 PM   #3
import36
import36's Avatar
thanks for the reply.
i'll be running 18's though....like my current setup....just a wider wheel by 1" in both the front and rear.
i was thinking i'd have to run something more along the lines of:
225/35-18 in the front
245/35-18 in the rear
...so as to avoid the rubbing.
      02-17-2013, 12:52 AM   #4
MonacoBlueE90
Finland
163
Oh my bad, some how i read 19 inch.Then i would say
225/40/18 or 235/40/18 to front
245/35/18 or 255/35/18 to rear
I have 18x9.5 et35 with 235/40/18 at my pre-lci E90 and it is 2mm from stock shocks. With coilovers you need more clearance ,because of those ride height adjustment.So you need probably 5mm spacer just to clear the coilovers or other option 10mm so you get hubcentric spacer.
You don't need 35 series tyre to front. If you go with 245/35 at rear then i would use 225/40 at front so that both front and rear have similar stretch.
This black E90 has 18x9.5 et20 225/40/18 and 18x10.5 et20 245/35/18 just to give you idea how it would look.
http://www.e90post.com/forums/showthread.php?t=737286
      02-18-2013, 12:35 PM   #5
import36
import36's Avatar
thanks a a lot for the info Monaco...very helpful!
