Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Runflats improve performance?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      02-14-2013, 12:52 PM   #1
Antartic
Antartic's Avatar
94
Drives: F80 M3 2018
I went to the dealer to see what it would take to swap my runflats for non-run flats.
The dealer said that runflats are better for performance for my 335i because the whole handling dynamics of the car was designed based on runflats. He added that the stiffer sidewalls of runflats help maintain their shape during hard cornering.
He agreed that non-runflats are quieter and provide a comfortable ride, but if it is performance that I am looking for (I am) then runflats are my best choice.
Do you guys think he is BSing me, or does he have a point?
      02-14-2013, 12:58 PM   #2
ctuna
1911
Drives: 325xi 06 wagon MT
Do a search there are so many threads on this.
I can tell you my friends that race will not have run flats
on there cars.
      02-14-2013, 01:01 PM   #3
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
1. Your dealer will only sell you RFTs so they have a financial interest here. Check out tirerack.com for more info.
2. Which RFTs and which non RFTs are you considering? There is a big variation among each so make sure you are comparing apples to apples.
3. In general, I prefer the ride and price of non RFTs. Handling is largely dependent on tread design and other factors - so some RFTs will outhandle some go-flats and vice-versa.
4. You'll probably get better responses in the Wheel/Tire forum:
http://www.e90post.com/forums/forumdisplay.php?f=12
Tom
      02-14-2013, 01:07 PM   #4
ChipB
ChipB's Avatar
Drives: 2015 M4 'vert, 2014 X5
Is he BS-ing you ? No, and yes.
No BS - the car is deigned with particular tire dynamics in mind, so if by optimal "performance" he means handling exactly as designed by the factory - then the stock RFs are it and anything else will be a little off.
But I call BS because your perception of "performance" is likely different than the factory's. As you've noted RFs tend to be noisy, and many think they are a bit "harsh" due to the stiff sidewalls. This hashness means more energy from bumps is transmitted through the sidewall to the wheel and into the suspension. Consequently many have reported that switching to non RF's makes for a more enjoyable ride. And any detrimental effect on handling (due to the slightly softer suspension system that you have with non-RFs in the mix) is so slight as to be negligible. Finally the actual performance available on non RFs in the after-market can exceed the stock RFs in grip, cornering, wet and dry traction, etc.
Bottom line is it's impossible to say whether changing will improve or worsen handling - you need to let us know specifically which model of tire you're looking at. One thing I wouild recommend is since your car originally came with summer tires (I believe), don't comprimise with all-seasons, but rather stick with summer tires in summer and winter tires in winter.
F83 M4 convertible, F15 X5 xDrive35i
Previous: E93 335i, E36 328iC, E28 528e, E21 320i
      02-14-2013, 01:07 PM   #5
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
it is true that the car's suspension was designed around being able to use runflats, however it will not make it perform any better by using them.
Runflats have their own flaws, that the suspension was designed to make up for.
Not having the flawed tires = better performance.
      02-14-2013, 01:16 PM   #6
sohlman
sohlman's Avatar
10
Drives: E90 330iSE
If the run flat tyre was a better performing tyre then the BMW M division would use them on the M3. They chose non run flat tyres. Enough said.
There is a number of reasons for run flats the main being weight saving of a spare, jack etc which helps co2 and emissions and safety in the event of a blow out
E90 330i SE Auto Graphite Grey Metalic
      02-14-2013, 01:28 PM   #7
raj55
Sweden
28
Drives: E91 2009, 320i
The run flats are great for high speed cornering ability and stability on the road when you are trying to avoid an obstacle but then you sacrifice ride quality since you have a less smooth ride (judder and bumps on the road are more easily felt with run flat). Personally, I feel that run flats are great for more aggressive driving style and are more safe if you have a sudden puncture during motor way driving. You are likely to have better control over your car in such a scenario. My summer tyres are run flat (faster speed on the road) and the winter tyres are non run flat (slower speed on ice and snow). So not every thing is bad with run flats.
      02-14-2013, 01:39 PM   #8
bender rodriguez
149
Drives: Audi
I don't like them because because places wont patch them..
      02-14-2013, 02:03 PM   #9
Antartic
Antartic's Avatar
94
Drives: F80 M3 2018
thanks for the replies guys. the current run flat tires that I have are performance summer Michelin Pilot Sport PS2ZP.
I was planning to get Pirelli P Zero Rosso.
I am not worried about the harshness of the ride or how easy it is to patch it- I want to make sure the car retains (or improves) the driving dynamics that it current has with RFT tires.
Most of the threads I searched for tires talk about the harshness and noise. Very few had any good discussions of performance (as far as I saw).
      02-14-2013, 02:21 PM   #10
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Ask the dealer if the factory puts RFT on the M3.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      02-14-2013, 02:27 PM   #11
edirtaynine
81
Drives: e92
Originally Posted by Antartic View Post
The dealer said
theres the start of the problem right there
e90post killed plastidip
Just say no to painted stock wheels
jm3as hooks it up
      02-14-2013, 02:34 PM   #12
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
That is true, but it is not really an "advantage". Because RFT are so bad, the shocks have to overwork.
If that was the case, non-RFT super summer performance xtreme add your superlative Michelin Pilot tires would be as stiff as RFT. They are not.
All I know, is that I preferred the handling of the non-RFT tires by several parsec. It does feel a bit soft on the stock shocks, but it has very predictable limits, RFT tend to loose it more abruptly, I don't like that.
      02-14-2013, 03:10 PM   #13
335BBS
55
Drives: 2009 335 coupe.
WRONG. Salesman is full of it. Sidewalls being this stiff HURT handling. At city speeds they feel more responsive but at speed they are not. Try going through a corner and hitting a bump......car jumps sideways as sidewall is so stiff. We need Captainaudio to explain slip angles again. Sidewalls need to flex more that rft to maintain grip.
      02-14-2013, 03:49 PM   #14
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
Drives: 2011 335 E93 M-Sport
Your dealer handed you a line of bullshit. They are expensive and OEM for any dealer. I swapped my RFTs years ago and sold them. Never looked back.
      02-14-2013, 03:57 PM   #15
derrick603
55
Drives: 2007 335i
Agreed. Keep in mind that the sidewalls of an RFT are designed to be stiff for run-flat purposes, not specifically for performance. There is no reason that a max performance non-RFT could not be designed with the same level of sidewall stiffness if it was an advantage.
      02-14-2013, 03:59 PM   #16
MrDummy
→сяuisiиg iи му вмш←
MrDummy's Avatar
Drives: 2010 Space Gray 328i
2010 BMW 328i  [0.00]
I want to switch but I only have stock 16" tires so its not worth it IMO.
Until I figure out what rims to get to replace current ones. I don't know how big I can go? Would 18" RIMs be the largest I should go with?
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i
ProGaMeR on the XboX 360
      02-14-2013, 04:37 PM   #17
335dFan
Jumping Jack Flash
335dFan's Avatar
Drives: 2021 X3 M40i
This may be the default dealer SA response, since the dealer near me said almost the same words ("whole package was designed as a system and the DSC and everything else is all engineered to work together"). Looking at it from the dealer's point of view (forget about the financial aspects for a minute), they may be weary of customers making their own changes outside of the BMW party line, and then running to the dealer when something is not right, and it relates to something the customer did outside of BMW's comfort zone. There is always some consequence for each of our choices. Nothing wrong with that.
I just listen to all sides, read a lot on the forums and other places, make my choices in as informed a way as I can, and accept the results and consequences, or trip up and try something else. On the tire issue, I ended up just putting RFT Blizzak LM-25 on for the cold season, and I will probably put non-RFT on when the warm weather comes back, even though I have a lot of tread left on the OEM RFT all-seasons. The logistics influenced me, because I want to leave the winter tires on the OEM wheels, and the OEM RFT all-seasons won't fit on the new wheels I want, so I decided to bite the bullet. Now the only decision is whether to buy a fifth wheel and tire, or get one of those aftermarket spares.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d
Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al.
      02-14-2013, 05:16 PM   #18
j2m
j2m's Avatar
180
Drives: '11 E92 M3 DCT
2011 BMW E92 M3  [10.00]
Your dealer is full of SHIT!
**tell them I said so**
11' E92 M3 Space Grey | DCT | ESS VT2- 625 | Gintani Race (valved) + Quad Res Catless X-Pipe | KW Sleeve's | GC Camber Plates|Arkym Diffuser | Vorsteiner VRS Lip | P3 Boost Guage | Stud Conversion
PHOTO's: Click Here ESS VT2 625 PHOTOS: Click Here
      02-14-2013, 06:27 PM   #19
tunachris
tunachris's Avatar
Drives: 2010 E92
2010 E92  [0.00]
Best move I ever made was switching to Michelin Pilot Super Sport non run-flats. Only problem is I go through tires at a horrendous rate. I get about 25,000 on the fronts, and at best maybe 12-13K on the rears.
JB4, BMW Perf. Exhaust, DCI, Strut Brace, KW Series 1, Quaife LSD, Black Kidneys.
      02-14-2013, 06:42 PM   #20
AWil335i
AWil335i's Avatar
12
Drives: 2007 E92 335i
The PS2 RFTs aren't bad, but I just switched to Pilot Super Sports and they definitely have more grip.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS DPs | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
      02-14-2013, 09:35 PM   #21
chromisdesigns
45
Drives: 2008 BMW 335i sedan
+1000! That's the story, right there...
I hated the OEM Bridgestone bricks on my 2008 335i -- got rid of them just as fast as I could. I particularly disliked the way they hop on bumpy corners, the car literally went sideways when the tires got air in the corner.
Since driving around the SF Bay area is a study in lousy road surfaces, I am MUCH happier since I sold them to a guy looking for lease return tires and got some **real** tires on the car.
Not to mention, the non-runflats are cheaper and last half again as long in addition.
      02-14-2013, 11:10 PM   #22
driverman
Drives: 2008 328i 6MT - SOLD
This statement from the OP is true: "the whole handling dynamics of the car was designed based on runflats".
It's also true that the M3 doesn't use RFT's.
So how would our sport suspensions be different if BMW designed them for non RFT's? Does anyone know? I've read BMW used softer bushings to make up for the stiff sidewalls.
After running original OEM Bridgestone RFT's then PS2's then DW's, I can tell you they all feel quite different. I can also tell you that DW's are 30 pounds lighter (as a set) than RFT's.
Captain Audio posted good stuff on slip angles that explains why RFT's don't handle better even though they have better steering response.
