The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > M3 Strut Brace Install Problem
      02-11-2013, 08:34 PM   #1
steven26
Drives: 2018 F80 M3
I currently have a problem installing the M3 strut brace. The rubber inserts in the plastic piece where the V brace goes through does not unclip. It looks like its one piece. A picture of it is posted below. Btw, this is going on a 2011 335is so maybe the newer 335's are different? Anybody else run into the same problem?
Front
Back
      02-12-2013, 05:43 AM   #2
Phil325i
Phil325i's Avatar
United Kingdom
616
Drives: E92 325i MSport Coupe
Steven I assume you've seen this..?
http://www.billswebspace.com/335M3St...stallation.htm
Seems like he had similar issues.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      02-12-2013, 08:22 AM   #3
MikeR1994
Drives: 06 e90 325i, 05 325Ci (RIP)
2006 BMW 325i  [0.00]
I have a pre lci e90 and that cowling or whatever it's called doesn't have those. Might have to do a little cutting, but obviously don't do that unless you have no other option, haha.
      02-12-2013, 11:27 PM   #4
steven26
Drives: 2018 F80 M3
I have seen that. I did not have a similar issue since his rubber pieces is clearly held on by clips.
So yours rubber pieces looks like it cannot be removed either?
      02-13-2013, 02:26 AM   #5
klov335
13
Drives: e90 lci n55 xdrive
mine didnt fit.. but i made it fit with some grease LOL it was a pita.. keep trying
      09-06-2013, 06:01 PM   #6
sutter2k
Drives: 2010 335i
dealing with this now. I am considering slitting the rubber boots. they are no longer detachable
      09-07-2013, 10:50 PM   #7
Everfly
Everfly's Avatar
154
Drives: BMW
Why u try to remove that rubber piece?
      09-08-2013, 01:56 AM   #8
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
Pre-LCI here. No issues whatsoever installing the M3 strut brace.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      09-08-2013, 02:09 AM   #9
j23a45m
j23a45m's Avatar
Drives: 2012 E70 X5
just about to order this. just a small alteration needed I guess or is this just a 335is issue
2011 BSM 335i E90 MTECH 6MT • JB4 stage 2 iso 5.3 FF wire• BMS Intake • Vishnu DP • Cyba Scoops • LUX V4 • 6000K Headlight/Fog light Philips Ultinon • Euro headlight switch • ACS roof wing • 35% tint • Performance Grilles • Misc coding • Cobb charge pipe • ///M3 fenders • 335is pedals • BC Coilovers • Vrsf 7" IC • ///M3 mirrors •
      09-08-2013, 02:42 AM   #10
steven26
Drives: 2018 F80 M3
I ended up slicing the rubber pieces on one end in order to fit the V-brace.
      09-08-2013, 08:59 AM   #11
LMB335IS
Sua Sponte
LMB335IS's Avatar
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
Had the same problem with my '13 335is. Luckily the member I bought my M3 brace from included the correct heater closing panel and grommets.
http://www.realoem.com/bmw/showparts...28&hg=64&fg=10
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      09-08-2013, 11:30 AM   #12
sutter2k
Drives: 2010 335i
ditto.
My alternations also include: using a dremel to take a little length off the bolts in the image below, so the ends didn't protrude in to the cowl so much.
. I saw another member actually drilling wholes in the plastic cowl. Taking a little off the bolts seems like a better option.
also, I pulled out one clip for the washer fuild line mount(had enough fighting to push triangle brace in).
      09-08-2013, 01:47 PM   #13
LMB335IS
Sua Sponte
LMB335IS's Avatar
Here's a look at how mine ended up with the M3 cowl conversion as well.
      09-08-2013, 07:51 PM   #14
vasillalov
vasillalov's Avatar
1121
2023 BMW M3  [0.00]
OOOOH! Me likey!
