2nd gear grinding
08-26-2007, 03:07 PM | #1 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
2nd gear grinding
Since Ive had the car sometimes it grinds in second gear. It doesnt matter if Im shifting fast or shifting soft. It will just not line up and grind. Ive made it a point to make sure my foot was completely down on the clutch but to no avail. This was happening before and after the CDV so that isnt the culprit. Its only second gear also, none of the others and only when upshifting. Im thinking its gotta be the synchros but Im sure BMW would place the blame on my mods or just say they couldnt replicate the situation.
Anyone else getting this as well?
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
08-26-2007, 03:09 PM | #2 |
89
Rep 3,011
how many miles on the gearbox? mine did it early (first 5K) but has not been an issue for a long time (currently at 24K)
"Teach the ignorant. Ignore the stupid."
08-26-2007, 03:31 PM | #3 |
342
Rep 6,188
Just crossed 5k the other day.
13 HD FatBob
08-26-2007, 03:35 PM | #4 |
95
Rep 2,573
Drives: AW DCT M3
You know, my first few hundred miles I would grind when I'd do some faster shifting, but since then, I have ( 0 ) grinding and I haven't changed my style of shifting.... Im with you on it being synchros
08-26-2007, 04:43 PM | #5 | |
AC
95
Rep 2,387
Your Supreme Leader
08-26-2007, 11:40 PM | #7 |
The limit of adhesion is my home.
1702
Rep 3,778
I used to get it as well.....kinda sucked. But i think, like CHESMU, I may have gotten used to it after 5K-6K hence it not happening to me anymore. FUnny thing is I still "fear" it coming so I think I now unconsciously shift with a delay to make sure the gear gets into place. This of course results in a not-so-smooth 1st to 2nd gear shift. But since my CDV is out, I don't really want to go back to the dealer to have them look at my syncro.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
08-27-2007, 08:13 AM | #8 |
1013
Rep 1,268
I am having the same problem. There is definitely something wrong with the 1st to 2nd sunchro, Some times when I shift to 2nd and I know I had the clutch all the way down the shift stops as if you fully engage and then when I let the clutch out it grins. Even if I push the clutch back in and try to pull back further it will not go, I have to shift out of 2nd, into neutral then let the cluck out and back in then it will engage 2nd.
I got almost 10K on mine and I am about to take it in for the yearly service so I am going to get this documented so it fails later I made sure they knew about now. |
08-27-2007, 08:45 AM | #9 | |
342
Rep 6,188
13 HD FatBob
08-27-2007, 02:06 PM | #10 | |
Klaatu Barada Nikto
30
Rep 1,169
08-27-2007, 02:11 PM | #11 |
342
Rep 6,188
No, I meant what I said. Using the shift lever as a crutch for holding on in a turn. Like using your knee against the side of the door to keep you in place. I could see that if Im doing that while shifting, then Im not pulling back on the shifter straight like the other poster mentioned.
13 HD FatBob
08-27-2007, 02:16 PM | #13 |
342
Rep 6,188
Thats what Im saying I have to start paying attention to. I dont do that when Im just driving around turns. Im saying if Im shifting in the middle of a turn do I do that?
13 HD FatBob
08-27-2007, 03:33 PM | #14 | |
Klaatu Barada Nikto
30
Rep 1,169
09-13-2007, 09:33 AM | #15 |
25
Rep 452
HyperM3,
Are you still getting a grind? My problem has been 5th gear not 2nd, but the symptoms are similar enough. My dealer claims to have changed the entire transmisssion, but the problem still persists. Your dealer may very well claim to not be able to duplicate your problem, but you just need to ask to have a dealer rep come with you so you can demonstrate. Through my research, I've noticed that 2nd gear is the most common gear to grind. Have a read through this thread? http://www.e90post.com/forums/showthread.php?t=76629 Mine is an ongoing saga yet to be resolved... Good luck
2008 E90 328i - Sparkling Graphite/Terra/Dark Burl, 6MT, Sport, Premuim, Fold-down seats, iPod/USB(6FL). M-Sport Steering Wheel, ZHP M-Sport Shift knob, Euro fog lights. Euro Split Armrest
09-13-2007, 01:34 PM | #16 | |
342
Rep 6,188
That being said, Ive been paying attention to the way I shift and it seems to have gotten better. Although its mostly under hard acceleration that it wants to grind, like the flywheel wont stop spinning to let the clutch engage.
13 HD FatBob
09-13-2007, 01:39 PM | #17 | |
Galactic Emperor
75
Rep 801
I used to grind too and then discovered that I was pulling slightly to the left. Must have been penned up tension in my right hand that I was trying to relieve . I started shifting very formal, sort of going back to basics and found that when I am a sloppy driver I get sloppy shifts. When I sat correctly, had good posture and gripped the stick correctly I could slide through the gears pretty easily. |
09-13-2007, 02:09 PM | #18 | |
25
Rep 452
At times, mine is so loud the vibrations are so great, that is seems as if you are travelling on the "you drifted over the white lines so wake up" strips on the side of the highway. Its serious, so I have no choice but to follow up. I certainly don't want to foot the bill on a what will surely be an expensive fix when car hits 51,000 miles.
09-13-2007, 03:20 PM | #20 | |
342
Rep 6,188
13 HD FatBob
02-07-2011, 09:32 PM | #21 |
Rookie
Rep 17
I have had a few of those incidents happen in the last 2 year but I've ignored them. Today, however things really hit the fan. I went from 1st to 2nd at about 5500 rpm and I heard a loud bang. 2nd gear completely went on me and the car only has 23000 miles and is a lease. I wonder if it's covered by warranty. I really hope so.
02-07-2011, 09:37 PM | #22 |
342
Rep 6,188
^ you might win for resurrection of oldest thread
13 HD FatBob
