BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Fuse location for Nav Screen
      08-26-2007, 01:06 AM   #1
robbie211
Drives: E90 335i, E36 M3
2007 335i  [6.76]
I am in the process of installing a TVandNav2Go module. I wired everything up and it worked fine. I put everything back together and now the Navigation screen doesn't light up. I get radio and cd but it looks like the backlight for the screen does not come on. Does anyone know the location of this fuse?
      08-26-2007, 11:24 PM   #2
alistair
alistair's Avatar
Drives: 2013 X5 ///M
2013 BMW X5///M  [0.00]
It's more likely that the cable isn't seated properly..... I don't think there is a fuse that covers just the iDrive screen backlighting (and not other components, like iDrive itself, or the radio)
      08-27-2007, 12:14 AM   #3
ntpcrew13
ntpcrew13's Avatar
Philippines
108
Drives: Arctic e90 330i
you might want to check if the cable that came with the module is plugged in correctly. im talking about the black cable that plugs into the nav screen and the module. you might have plugged it in backwards. i believe there is a white dot on the end of the black cable used as a marker.
......support your local vendors. view my garage for a list of mods.
      08-27-2007, 12:39 AM   #4
robbie211
2007 335i  [6.76]
Thanks for the help guys...It was a fuse and I was able to fix it
      05-29-2010, 07:57 PM   #5
empire328
empire328's Avatar
7
Drives: 2007 328xi montego blue
i know this thread is old but can you guys tell me what fuse it was??? thanks!
      06-15-2010, 02:57 PM   #6
330iLiiike
Drives: 2006 330i
can you tell me what fuse it was, thanks
      06-17-2010, 03:42 AM   #7
empire328
empire328's Avatar
7
I changed out my fuse for the glove box and trunk light and my screen cut right back on!
check and swap that fuse hopefully it works.
