Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > ?'s about rear brake replacement (zimm. z-coat + only doing the rears)
      02-10-2013, 12:59 PM   #1
AllBlackBimmer
AllBlackBimmer's Avatar
815
Drives: 2019 X3 m40i
OK I finally decided I am going with stoptech or Zimmerman rotor and probably hawk hps pads.
now my ? Is, I only need to replace my rear rotors/pads at the moment, fronts won't bye due til end of summer or fall.
if I replace just the rear with stoptechs and hawks and leave the front go for now, is that going to screw my braking up? Do I need to do front and rear at the same time?? Will I have braking issues?
any reason to NOT go with stoptech or Zimmerman rotors? I am pretty sold on hawk hps pads for my daily driver.
EDIT: where can I get zimmerman rotors that will be Guaranteed with the Z-coating?
... I also looked into Meyle rotos from ECS but may want to stick with the zimmermans z-coat if I can find them.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710
      02-10-2013, 10:50 PM   #2
will.c
will.c's Avatar
Drives: E46M
all of the mentioned items should be fine. You can even go cheaper and get some Centric rotors from Tirerack.com. I've even tracked with these without any problems.
      02-11-2013, 07:12 AM   #3
AllBlackBimmer
815
what about only replacing the rears for now and having Hawk HPS on the rear with the OEM old pads/rotors on the fronts until they wear out?
if anything, I will shell out a little more $ and get the z-coated zimmerman rotors.
Not sure if the brembo has a blank-oem rotor with z-coating?
Will be looking for venders to buy all this from... GTB Performance has the best Hawk pad prices..
what about rotors?? looking for zimmerman z-coated but need to be SURE they will be coated ... i know some vendors cannot guarante this
      02-11-2013, 10:49 AM   #4
AllBlackBimmer
815
... now I am questioning if I should go with the zimmerman z-coat rotors which seem to be hard to find and a vender that can GUARUNTEE they will be coated when i get them...
.. also looking at the stoptech rotors...
so.. zimmerman z-coat or stoptechs? not sure if the stoptechs have a coating or not?
      02-11-2013, 05:07 PM   #5
will.c
will.c's Avatar
Drives: E46M
No prob, just do the rears for now.
Hey man, whatever makes you happy. but I've run many rotors at street and track, including OEM 335i sport, OEM Z4 3.5is "2 piece" (close to $400 for a set of fronts!!), and Centric 125 from Tirerack.com. I could tell absolutely no difference between any of these.
again, to me, just snake oil...
cheapest vendor I found with good customer service and pretty quick delivery:
http://raceshopper.com
Just go to the web page of the item you're interested in, write some info down, then press "Get me a Quote," and they send you an email within a few hours.
      02-11-2013, 05:21 PM   #6
EJ_3
EJ_3's Avatar
Drives: e92 335i, e34 525i & e60 530i
2007 BMW 335i  [8.34]
2016 Ram 1500 Sport  [8.00]
1994 BMW 525i  [10.00]
2007 BMW 530i  [8.66]
I had those pads on my Altima back in the day. They were great. I can't speak on Zimmerman, but I can say you wouldn't be let down going with StopTech. Just change out the rear and do the fronts when needed. If you have the brake light on your dash, don't forget to pick up a new brake pad sensor.
      02-11-2013, 05:58 PM   #7
AllBlackBimmer
815
Go figure, I changed my mind... again...
now leaning towards getting stoptech/centric rotors with the painted hubs and stoptech street performance pads...
      02-14-2013, 11:11 AM   #8
ashmostro
Drives: 2020 M4cs | 2022 M550i
Rotors doesn't matter if you do F+R separately.
Pads, make sure your higher friction compound is on the front, not the rear. Preferably matched compounds unless you are tracking.
      02-14-2013, 02:12 PM   #9
ashmostro
Said another way, I do not recommend running Hawk HPS pads in the rear if you still have stock pads on the front.
      02-14-2013, 03:11 PM   #10
AllBlackBimmer
815
Well...
I am not going to run the HAWK HPS pads AT ALL. I have decided to go with Stoptech Street performance pads.
What would happen if I runa higher friction pad in the rear for a few months first before switching the fronts? Aren't the OEM pads pretty "high fricition" themselves, hence why all aftermarket pads don't have the same "bite" the OEM ones do (i undersntad most aftermarket pads, have less bite, but better linear braking overall)
      02-14-2013, 03:32 PM   #11
ashmostro
Got it.
The problem isn't intial bite- it's max friction level. If they are markedly different, your brake bias is going to be off... and if you want your brake bias to be off you want more front bias, not rear. Locking up or engaging ABS on just the rears can result in a slide faster than the fronts first. Yes, our ABS sytems have proportioning valves to compensate but that takes time and is reactive, not proactive. You have to lose traction first before the compensation can measure and kick in the right amount of modulation.
If your friction coefficients are close, it's not a big deal. I don't know what the mu is on the Stoptechs vs stock, so I can't comment.
Just felt strongly enough about the potential safety issue to say something. Your call on what to do with that information. Take care.
      02-14-2013, 03:35 PM   #12
ashmostro
Oh, and the reason aftermarket pads dont have the initial bite of OEMs is because high-friction pads usually need more heat in them to reach those friction levels. But when they get up to temp, they will have more bite than stock- and the stocks will fade much sooner when they warm up and then you have the opposite effect. Another reason to stay with matched compounds (similar temperature effects).
fwiw.
      02-15-2013, 07:19 AM   #13
AllBlackBimmer
815
Thanks for the info...
What are people's thoughts on running the Centric Rotors + Stoptech street performance pads at ALL FOUR corners compared to OEM?
