BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Cost of new OEM Rotors and Brakes?
      02-06-2013, 11:54 AM   #1
dutch
Drives: BMW 335i
So I took my car into the dealership since it was due for some new brake pads, they informed me that the rotors were also below recommendation. Then quoted me $840 to fix it. That seemed a little high to me, even for a BMW, does this sound about right? or am I being taken for a ride, so to speak?
Thanks!
      02-06-2013, 12:09 PM   #2
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
That's not bad for all four corners. If that's just one axle buy your parts from ECS and go to an indie
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      02-06-2013, 12:21 PM   #3
dutch
Drives: BMW 335i
Yeah, I guess I should have been more specific. It's only for the front axle.
      02-06-2013, 02:22 PM   #4
phillip@bmpdesign
Drives: 2008 BMW 335i
Several reputable independent BMW shops will do it for less than $500 including sensors, OEM pads, OEM rotors, reprogramming, and bed-in.
Or you could do it yourself for around $300.
If this is your first brake service, and you have around 50k miles, I would also recommend a brake fluid flush.
Phillip Wilmeth
-=BMP Design=-
1-800-648-7278
Like us on facebook!
      02-06-2013, 03:48 PM   #5
techwhiz
techwhiz's Avatar
Drives: e90 335i Sedan - Arctic
Get the Z4 35is rotors. Better than the stock ones.
      02-07-2013, 01:46 PM   #6
Cir14
Drives: 11 328xi M-Sport Sedan
Im going to need new rear brakes in the near future. I don’t really have the capabilities to do it myself or the required tools. Can anyone recommend a indy shop in & around the Philly Area? That is for ~$500; I would rather support an indy than the dealer
      02-07-2013, 03:05 PM   #7
Hybrid For Life
Germany
79
Drives: Out of Spec
If you have basic tools you can do the brakes very easily your self. I did rotors and pads in the rear in about 3 hours. easy mode
      02-13-2013, 08:29 PM   #8
gds52
gds52's Avatar
886
Drives: BMW Z4M Coupe, BMW 328i E93 Co
VAC motorsports Philadelphia.
You can check they price with them.
They are experts.
      02-14-2013, 12:27 PM   #9
Cir14
Just got rear brakes (Rotors, Pads & Sensors) replaced for $494.76 at West German in Ft. Washington. Ive had the car since 51K, I have 83K now. Its a 6 speed which saves alot on the wear
      02-14-2013, 02:00 PM   #10
CJ421
CJ421's Avatar
1559
Drives: BMW M3
VAC Motorsports - www.vacmotorsports.com
Helix Motorsports - www.helix13.com
Two reputable shops in Philly. You may be closer to one or the other depending on location.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
