The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Due for rotors. Drilled, slotted, or both???
      02-06-2013, 11:05 AM   #1
dhanni848
38
Drives: 06 330i
Hello all,
As the title says, I am going to be replacing my rotors and want to upgrade a little bit. I have drilled and slotted rotors on my truck an have been pretty happy, but I was wondering what are your experiences. I am looking at some drilled only and slotted only, what would you go with based on your experiences.
Thank you!
      02-06-2013, 11:37 AM   #2
mike-y
just another bmw douche bag
Drives: 1.9L of fury
those rotors are only a visual upgrade. if you want a performance upgrade, get a more aggressive brake pad.
but for street driving, it really doesn't matter what kind of rotor you get. If you track the car, I'd get OEM (or equivelent) blanks.
      02-06-2013, 12:00 PM   #3
tofu-
87
Drives: 335i Jet Black/Coral Red
Originally Posted by dhanni848 View Post
Hello all,
Thank you!
i would just get slotted and dimpled for aesthetic appeal.
as the other guy said, you won't notice any difference.
      02-06-2013, 12:28 PM   #4
dhanni848
38
Drives: 06 330i
Thank you that's all I needed to know. I don't track and am not that hard on my brakes but just figured I'd add a little better look.
I think I'm going to pull the trigger on the drilled only.
      02-06-2013, 03:48 PM   #5
techwhiz
techwhiz's Avatar
Drives: e90 335i Sedan - Arctic
Get the Z4 35is rotors with the aluminum hats. Technically a two piece rotor.
      02-07-2013, 07:13 AM   #6
TOPEC
<3 Flat Four
217
Drives: 335is LM Blue
get slots, the slots will "shave" off a layer of pad so every time u use ur brakes theres a new layer of clean pad to make contact with the rotor surface, down side is increased pad wear n noise
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White
      02-07-2013, 08:07 AM   #7
BoostedE90
BoostedE90's Avatar
Drives: e90 335i 6MT
I would avoid drilled rotors. First off the drilling weakens the structural integrity of the rotor and in most cases the rotors will develop small cracks where they are drilled from the heating and cooling of the rotor. Also cross drilled rotors have less contact area because of the holes. The reason for the creation of cross drilled rotors initially was to remove the "gasses" from the brake pads. However, most modern brake pads do not produce gasses when heating.
I know you said you were going for aesthetics, but rather than drilled rotors I would get dimpled and slotted. To be honest unless you are up close to rotor you can’t tell the difference between drilled versus dimpled. Just my $.02
      02-07-2013, 01:11 PM   #8
dhanni848
38
Drives: 06 330i
I want to stay away from noise as much as possible. I had never heard dimpled rotors before.
      02-07-2013, 01:18 PM   #9
Red_Bean_Bun
62
Drives: E92
It exists and it look like it drilled half way through ....
      02-07-2013, 01:18 PM   #10
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
I have drilled and had no issues. You want a serious brand for drilled, not random ebay crap (not that you should get random crap for blank rotors anyway, but even less so). In particular, you don't want a good brand (blank) rotor that has been drilled by some random jackass on his man-cave drill press, like some ebay deals feature.
I have the stoptech, they look great and have been solid performers so far. The braking performance is very similar, I noticed that brake fading has been improved, but I compared with worn out OE rotors, many parameters beside drills could explain the improvement (first, the new rotors being thicker have more thermal inertia).
They have not cracked in the 8k miles I enjoyed them, and I am heavy on both pedals. Not recommended for track/autox use, as drilled rotors have been reported many times to fail in that context.
It is generally admitted that drilled rotors offer no performance benefit for street driving, and are unreliable for track, so that makes them cosmetic upgrade only.
      02-07-2013, 01:47 PM   #11
Hybrid For Life
Germany
79
Drives: Out of Spec
go with blanks or slotted
      02-08-2013, 06:49 PM   #12
BillionPa
BillionPa's Avatar
Drives: 335i
I almost did drilled and slotted, using the DBA 4000XS rotors, they look awesome. Ended up going with the DBA 4000T3 rotors, which have a pretty cool looking slotted design which should be a little nicer on the pads in terms of wear. They are in the trunk right now, gonna install on monday when the pads get here
      02-08-2013, 08:11 PM   #13
TOPEC
<3 Flat Four
217
+1 for dba rotors, they r really good stuff
      02-08-2013, 08:49 PM   #14
BillionPa
BillionPa's Avatar
Drives: 335i
I also live close to the FrozenRotors facility in Minnesota, about a 30min detour on my way to work, so I had them cryo treated as well, $60 per rotor. I do not expect to replace these for a VERY LONG time, unless I get enough money to track the car, then I will pick up a 5000 series just for use with racing pads.
      02-09-2013, 04:55 PM   #15
dhanni848
38
Drives: 06 330i
Those look sick! Unfortunately I would assume those are pretty pricey? I had to buy rotors for my car and the wife's MKX as well so definitely had to sacrifice a little.
I ordered drilled a few days ago before everyone said don't do it. I've never had trouble out of my others and I got the same brand so hopefully my luck will be just as good.
      02-10-2013, 02:16 AM   #16
BillionPa
BillionPa's Avatar
Drives: 335i
I got the front pair for $330 before cryo treating, $50 over stock. I would not consider that expensive for the quality and performance involved, due to my luck with the stock rotors.
I may replace my rears with cross drilled when the time comes, but will almost certainly go with the DBA rotors again, the gold ones.
      02-14-2013, 08:21 PM   #17
fibonacci
Fancy Member
8
Drives: 2007 335i
+1
      02-17-2013, 01:22 PM   #18
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Hello all,
Thank you!
Slotted for best performance and longevity.
      02-17-2013, 11:24 PM   #19
psmitty95
psmitty95's Avatar
Drives: '23 M340i xDrive
These look awesome, do you have any pics of them mounted?
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion
Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning
More Pictures: Build Thread /// 683AWHP/675AWTQ
      02-22-2013, 01:41 AM   #20
BillionPa
BillionPa's Avatar
Drives: 335i
why yes, yes i do
      02-23-2013, 05:19 PM   #21
dhanni848
38
Drives: 06 330i
Installed my drilled rotors today and I am very happy so far. There is no noise and stopping is smooth. And not to mention they look great.
Any of you guys that use blanks for racing, do you turn your used rotors and use then for racing again? Asking because I would like to sell my blanks. The rears look great, fronts could be turned I believe. I know this is the wrong section but I just wanted some input because I don't track and don't need them.
      02-23-2013, 05:31 PM   #22
BillionPa
BillionPa's Avatar
Drives: 335i
what brand did you end up getting?
I assume people who are racing their cars are NOT using OEM rotors, at least there is no way in hell I would (for the fronts anyway)
