BMW X3 Forum
BMW X3 Forum
      02-01-2013, 07:12 AM   #1
neelkc12
neelkc12's Avatar
Drives: x3
2011 BMW X3  [0.00]
Lightbulb E83 wheels on F25 did not fit !
Picked up E83 wheels and winter tires from salvage yard ( nice and gorgeous tire rack sports edition wheels) hoping they would for on my 2011 F25. Many threads on this forum suggest that they should fit . I also got new bolts ( M14x1.25) from tirerack . Alas they did not fit. - Calipers were too tight ( absolutely no clearance) and the wheel did not move at all. What am I missing ? Thought about wheel spacers and asked a local BMW indy about probable size of wheel spacers. He could not help either.
Technical details :
Basic wheel specifications for the X3(F25) chassis are:
Bolt Circle = 5 X 120mm
Offset = 45mm (43 to 47mm acceptable)
Hub centering Bore = 72.5 mm (hub ring dia. = 72.47mm)
Bolts = M14X1.25 Spherical seat, 17 mm heads (Note the X3(E83) uses M14X1.5 bolts)
Minimum bolt engagement = 9.5 turns
For E83 all same except the bolt sizes
Bolt Pattern: 5x120 | Center Bore: 72.56 | Hardware:12x1.50 Bolt | Offset: 34-45mm
Also, I could see the wheel after mounting it that it not flush against the hub , where as my OEM wheels are!.
Thoughts , before I put wheel and tires on craigslist.
      02-01-2013, 09:13 PM   #2
AW328i
Member
AW328i's Avatar
Drives: Range Rover Sport
I'd definitely try some small spacers man if that's all the issue is, as long as the offset will look proper.
      02-15-2013, 06:12 AM   #3
urquattro83
Drives: 2007 X3 3.0si M Sport
Is the "look" you refer to more important than proper fit?
      03-01-2013, 09:40 AM   #4
Ranger 6
Yorkshireman trapped in a Berkshire postcode
Ranger 6's Avatar
United Kingdom
12
Drives: X3 3.0d M-Sport
2008 BMW X3  [0.00]
Just returned from a skiing trip to the Alps and saw an F25 parked at the side of the road with E83 Style 143 and winter tyres. Obviously I couldn't tell whether it had spacers or not.
When you say the calipers - do you mean the wheel isn't big enough(diameter problem - e.g. 17s won't fit a 35d but 18s will) or the spokes are catching(offset problem)?
X3 3.0d M-Sport
Mini Countryman Cooper S ALL4
      03-04-2013, 08:24 AM   #5
neelkc12
neelkc12's Avatar
Drives: x3
2011 BMW X3  [0.00]
spokes are catching(offset problem). I guess I would have to do my due diligence of doing all measurements and order some wheel spacers.
      03-04-2013, 08:41 AM   #6
Ranger 6
Ranger 6's Avatar
United Kingdom
12
2008 BMW X3  [0.00]
Thanks - are you using OEM wheels?
X3 3.0d M-Sport
xbimmers
